Author Topic: Possible replacement indicators  (Read 5066 times)
« on: 24, December, 2011 - 16:01:17 »
Found these in my local Range store
Set of two flasher lamps with bulbs £2.99. Look like they would make good indicators for the C5 - they also seem to do white, blue and red, though I only spotted white.
Would these be easy to wire up for a dunce like me?
Re: Possible replacement indicators
« Reply #1 on: 25, December, 2011 - 09:07:04 »
..anything is possible mate , I like the small round ones that Plod fitted as well.
« Reply #2 on: 29, December, 2011 - 11:00:02 »
Hi thedesintailor,
You can use these or any other indicator and use the standard C5 wiring details for fitting the indicators. All you will need is to get a flasher unit (2 pin version - 2 x untested versions below) and a three position switch from someone on the forum or ebay, wire (can get colour as from Maplins, ebay and DIY stores) and a 5 amp connector strip again from ebay, maplins or a DIY store.
http://www.c5alive.co.uk/pub/downloads/C5-UnofficialServiceManual.pdf
http://www.ebay.co.uk/itm/12V-FLASHER-UNIT-2-PIN-18-23-W-MEDIUM-WRE08-NEWFREEPOST-/110792816435?pt=UK_Motorcycle_Parts&hash=item19cbc43733
http://www.ebay.co.uk/itm/12V-FLASHER-UNIT-MAX-47W-AUTO-CAR-ELECTRICAL-FL1-NEW-/280712819468?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415bc9b30c
http://www.ebay.co.uk/itm/Car-Van-Boat-3-Position-Dashboard-SPDT-Rocker-Switch-/170658493339?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item27bc09f39b
Or you could speak with Chas as he has made wiring harnesses and flasher (Hazard warning) systems.
http://www.ebay.co.uk/itm/SINCLAIR-C5-HAZARD-WARNING-FLASHER-KIT-/220907007618?pt=LH_DefaultDomain_3&hash=item336f156e82
« Last Edit: 29, December, 2011 - 11:20:20 by Lancealot »
« Reply #3 on: 29, December, 2011 - 11:41:54 »
Hi regarding the flasher unit you must make sure that it will work on the C5 (the front and back L/R bulbs total up to 15 watt per side only ) so not sure if they would work .
« Reply #4 on: 29, December, 2011 - 13:02:17 »
Thanks guys - looks well out of my comfort zone.
