Author Topic: Horn ****Got one now****  (Read 4247 times)
Re: Horn
« Reply #15 on: 07, January, 2013 - 09:15:47 »
Luke as advised I cannot upload it to the forum hence they were emailed to you. Have you worked out which is the C5 one and which is the one from Maplins............... ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ::)
Recording 1 - is C5 original
Recording 2 - is Maplins
Or is it................................ :o :o :o :o :o :o :o :o :o :o :o :o :o :o
Re: Horn
« Reply #16 on: 07, January, 2013 - 20:38:05 »
They sound identical to me. I'll see if I can get the one from Maplins, it would be easier. ::)
Re: Horn
« Reply #17 on: 07, January, 2013 - 20:45:59 »
A lot less hassle as well
Re: Horn
« Reply #18 on: 07, January, 2013 - 20:58:27 »
And a lot cheaper. They are 3v to 24v as well...................................
I am going to use it on my conversion.............
Re: Horn
« Reply #19 on: 08, January, 2013 - 17:57:32 »
I'll be getting a 12v one for my c5 hopefully
Re: Horn
« Reply #20 on: 08, January, 2013 - 20:42:01 »
Hi Luke the one I have works from a voltage of 3v all the way to 24v. I tested it using standard 12v.
They are from Maplins FK84 @ £3.59 each.
Here is a photo of the original fitted in the C5 and the one from Maplins.
Re: Horn
« Reply #21 on: 08, January, 2013 - 20:44:57 »
Thanks  ;) ;)
Re: Horn
« Reply #22 on: 02, February, 2013 - 19:08:21 »
It was sheer luck that my dad found a switch for the horn identical to the original.
Getting the horn from Maplins tomorrow
Re: Horn
« Reply #23 on: 08, February, 2013 - 21:31:06 »
This advert is now finnished
Offline danny7147
  • Battery level: 10
    • Bikes To The Future
Re: Horn ****Got one now****
« Reply #24 on: 08, February, 2013 - 22:12:02 »
What have you done about the microswitch though? Have you managed to find a way to operate it from the handlebars? I've always wondered if there's a way to do that... Like if the power button to turn the motor on broke!
« Reply #25 on: 09, February, 2013 - 08:15:31 »
Yes we are using the micro-switch on the handlebars. My dad made a bracket for it so it could mount on the handlebars  ;) ;)
« Reply #26 on: 10, February, 2013 - 12:05:30 »
