Author Topic: New restoration for Chris  (Read 13775 times)
« on: 06, August, 2015 - 20:49:43 »
Hi all just starting a new restoration for Chris
Just stripped it down .
Now the work starts .....
Re: New restoration for Chris
« Reply #1 on: 07, August, 2015 - 07:45:44 »
Here is the body
« Last Edit: 07, August, 2015 - 08:39:10 by C5 ENTHUSIAST + RESTORER »
« Reply #2 on: 08, August, 2015 - 15:53:22 »
Hi all just finished the chassis
Offline C5 Josh Langstaff
« Reply #3 on: 09, August, 2015 - 10:12:21 »
looking good chas
« Reply #4 on: 09, August, 2015 - 19:31:36 »
Gave the body a good clean but it will need another one later .
Looking ok
Working on the chassis
« Last Edit: 09, August, 2015 - 19:35:27 by C5 ENTHUSIAST + RESTORER »
« Reply #5 on: 09, August, 2015 - 19:46:06 »
my c5 is in decent condition , hgow much would it cost if i got you to restore it for me
Offline chrisjones
« Reply #6 on: 10, August, 2015 - 07:50:16 »
Looking good chas, cannot wait to see it all finished, how is the body looking? Looks good in the pictures.thanks again for building it.
« Reply #7 on: 10, August, 2015 - 08:21:33 »
Hi there Chris it's loƓking great more photos to follow
« Reply #8 on: 10, August, 2015 - 18:57:32 »
Wiring fitted .but not checked yet
Body fitted on chassis brake cables fitted all wheels fitted
New Trunking needs to be fitted
Now fitted
« Last Edit: 10, August, 2015 - 19:12:46 by C5 ENTHUSIAST + RESTORER »
« Reply #9 on: 12, August, 2015 - 17:03:48 »
Stering  sorted now the brakes and start + horn switchers to fit on
Started fitting the peddles + the bottom crank and chain
Hi just cleaned the body again looking good
« Last Edit: 15, August, 2015 - 21:37:55 by C5 ENTHUSIAST + RESTORER »
Offline chrisjones
« Reply #10 on: 13, August, 2015 - 09:45:41 »
Hi chas, looking good, thanks for posting updates on the build, looks like its flying along!
« Reply #11 on: 13, August, 2015 - 20:17:38 »
Started working on the motor .Stripped it down checked it replaced the gearbox bearing all the old grease taken out
Cleaned all the parts and rebuilt it with new grease in the gearbox ...
Tested it al works great .
« Last Edit: 15, August, 2015 - 21:45:53 by C5 ENTHUSIAST + RESTORER »
« Reply #12 on: 17, August, 2015 - 07:58:58 »
Hi started to check out the wiring / control box / and the pod
All seems to be ok but it will need a few test runs to make sure
« Reply #13 on: 17, August, 2015 - 14:45:24 »
Started cleaning the wheel trims
« Reply #14 on: 23, August, 2015 - 19:03:10 »
Hi Chris had a test run today all went well but only a short run due to rain will try again later this week if all is ok I will put the mud flaps on and replace the wheels as I use an old set just for testing
Photos will follow later
All the best Chas
