C5 Help > Tried & Tested : Share your good,or bad, experiences
Victron AGM and PBQ battery
gertk:
Today I found this:
http://www.awaccu.nl/product/221-55ah-semi-tractie-agm-accu-onderhoudsvrij-gesloten
It seems to have the perfect dimensions for fitting the original lid, I have mailed the supplier to make sure it has a 'left positive' terminal. Some thick brass plates could make the link between the poles and the lid.
Ton C5:
here the data sheet, there are even strips available to connect the cover
http://webshop.batimp.nl/webshop/pdf/LZAQLL12550.pdf
gertk:
I ordered the PBQ battery as it seems to be the best fit, fingers crossed :)
gertk:
Well, the PBQ battery itself fits perfectly in the C5: it clicks right into the bottom slot and underneath the retainer strip at the back. Alas I need to modify the lid as it is too high when fitted. Inside the lid there are some plastic strips I need to cut back so the lid will sit lower on top of the battery.
Alas, the retainer at the back seems to grab the lower rim of the Oldham battery (which is not present on the PBQ) so I had to make a spacer of about 17 mm between the retainer and the bottom. Now it sits firmly. I have modified the lid with a Dremel tool and made two small thick brass strips with a 6mm bolt on which the original nuts fit. From the top it looks quite original.
So far so good, still the keyswitch block does not make a reliable contact, I need to wiggle it a bit to get connection.
More investigation needed.
Next step: check the 'grease status' of the motor, wheels, steering and pedals.
gertk:
Some more pictures:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
