C5 Help > Tried & Tested : Share your good,or bad, experiences
Indicator option
(1/7) > >>
gertk:
I am contemplating using these:
http://www.marktplaats.nl/a/auto-diversen/autosport-onderdelen-en-toebehoren/a1001871459-nieuw-set-van-2-led-richtingaanwijzers-richting-aanwijzers.html?c=827ab967057e9f5ff33a0fad145c2c0e&previousPage=VIP_SIMILAR_LISTING
for use as rear indicator lights by mounting them inside the reflector unit (not sure if the reflector can be taken apart without much damage)
Luke S:
If you wanted to take the reflector out I think you will have to cut it out of the light.
They look good. Be great to see them attached to the C5 if you do fit them  :)
Luke S:
Also 10 times cheeper
kamilb1998:
They would look great if you could get them fitted, but I think the light would get damaged if you tried to take it apart.
gertk:
I ordered a set today, see what it is like.
To mount them inside the reflector I will probably dremel backpanel off (just the center light part, two thin slits) and slide the led panels in left and right.
Navigation
[0] Message Index
[#] Next page
Go to full version
