C5 Help => Components List => Topic started by: Paul on 27, March, 2014 - 23:43:03
Title: Drive motor brushes
Post by: Paul on 27, March, 2014 - 23:43:03
Hi to all, can anyone tell me where I can get brushes for the motor!
Thanks in advance
Title: Re: Drive motor brushes
Post by: kamztrad on 28, March, 2014 - 17:48:43
Just search this number on E-Bay :- 481281729457
I have used these no probs  :D :D :D
kamztrad
Post by: Paul on 28, March, 2014 - 21:31:20
Many thanks for that, can you tell me do they just pull out or do you have to take the motor apart?
Post by: kamztrad on 28, March, 2014 - 22:11:16
I have fitted new brushes by removing just the end cap that they are fitted in - the brushes are held in by plastic barbs on the end which spring open when the brushes are pushed fully home, which is why they are well nigh impossible to pull out without removing the end cap.
If you remove the end cap you should then be able to squeeze the barbs together and push the brushes out - then if you refit the end cap first you should be able to push the new brushes fully home and they should stay put, fingers crossed,
Hope this helps
kamztrad
Post by: Paul on 28, March, 2014 - 23:15:34
Thanks for all the advice Kamztrad, I will give it a try when I get the new brushes and hopefully the end cap will come off easy
