Author Topic: c5 chain needed  (Read 2953 times)
marcdonnelly
c5 chain needed
« on: 05, May, 2010 - 09:22:53 »
If any one has a used or new  c5 chain  can they please let me know
Re: c5 chain needed
« Reply #1 on: 06, May, 2010 - 06:13:56 »
The thing most do is buy two cycle chains and make one the right lenght for a C5, get a desent quality chain and you wont have any problems.
iDENTITi
Re: c5 chain needed
« Reply #2 on: 06, May, 2010 - 14:25:58 »
I know it sounds stupid... But if your going to use a bicycle chain from a shop, pay attention to the width of the chain.  I haven't had chance to measure the chainrings on the C5 (I misplaced my digi callipers) but I have a feeling they'l be 1/8th inch which is single speed bicycle chain.  Don't quote me on that.  I'm sure someone more knowledgeable will be able to come up with the measurement.
Re: c5 chain needed
« Reply #3 on: 06, May, 2010 - 19:27:25 »
Hi there just take the old chain with you to the shop //
Re: c5 chain needed
« Reply #4 on: 07, May, 2010 - 05:59:56 »
If you have any paperwork with your C5, I think I've seen the chain size and measurements in there somowhere, can have a look later for you if you like.
marcdonnelly
Re: c5 chain needed
« Reply #5 on: 07, May, 2010 - 09:32:01 »
Thanks andy that would be great if you could .
Re: c5 chain needed
« Reply #6 on: 08, May, 2010 - 09:45:53 »
Info from the Sinclair technical specification:- Chain 12.5mm (1/2") pitch x 3mm (1/8") 181 links.
hope this helps.
marcdonnelly
Re: c5 chain needed
« Reply #7 on: 08, May, 2010 - 10:06:25 »
cheers
