C5 Help => C5 Faults & Solutions => Topic started by: reality404 on 15, May, 2015 - 17:57:37
My motor armature bearings have snapped off. I'm guessing there is nothing I can do to fix it and will need find a new motor. Any advise on if I can fix it or finding a replacement motor would be helpful thanks.
(http://i.imgur.com/T3vGQ2t.jpg) (http://i.imgur.com/dYOhgjY.jpg)
(http://i.imgur.com/JzQYvtM.jpg)
It's a bit unclear when you write that the bearing has snapped off. A photo of the damage, or damaged part would help. Motor bearings are available, that is if it's just the bearing. Or is it that the bearing shaft has sheared?
Sorry I mean the shaft has snapped off. I did post some pictures of the damage but I can post more if you can't see it. Thanks
Hi- this is a fairly common failure point - you will indeed need a new armature assembly - if not a new motor - Would be worth contacting Chas as he may have some spares - Marty
