Author Topic: Going 24v : what's required ?  (Read 2832 times)
Offline minidaz
« on: 14, May, 2012 - 17:53:27 »
Going on from my post in the For Sale section, i thought i'd give it it's own thread.
I take it with the controllers, going direct to 4qd is a good option, and would i be right in saying that it's the uni-8 24 that's the choice of sprint champions  ;D
Obviously the controller is just part of what's required. Do 4qd do the throttle grips / wiring / all the bits and pieces to fit it, or would i need to purchase these from elsewhere ?
The need for speed is getting stronger  ;D ;D
marra
Re: Going 24v : what's required ?
« Reply #1 on: 14, May, 2012 - 17:58:04 »
I bought the controller + base, cover and leads and magura throttle twist grip from 4 qd. you dont need the extra length conti fit ( imo ).
« Reply #2 on: 14, May, 2012 - 18:07:33 »
http://www.4qd.co.uk/prod/uni.html
http://www.4qd.co.uk/accs/pots.html#mag
All the user / fitting manuals are also there to download if you want to have a look prior to buying.
« Reply #3 on: 14, May, 2012 - 19:26:22 »
...that will be down to the AER then  ;D
Basically the Throttle , matching handgrip for the other side and controller are from 4qd
The battery clamps, wiring , fan ,additional heat soak etc are sourced elsewhere.
Offline minidaz
« Reply #4 on: 14, May, 2012 - 20:40:11 »
Yep  ;D
Might have to see about a 4qd order sometime soon, but does anyone know where i can get a decent set of battery clamps from  :P ;D
Must admit i've never tinkered with the C5 electrics, but there's always a first.
And i know if i get stuck, there's a few experts on here  :)
« Reply #5 on: 15, May, 2012 - 07:29:50 »
Am looking into making up a harness to improve what is fitted to Goldfinger - if it works out ok your welcome to copy it - ps im just down the A14 if you get stuck bud  :) :)
Offline minidaz
« Reply #6 on: 15, May, 2012 - 18:14:18 »
Cheers Marty  :)
