Author Topic: STURMEY ARCHER 3 SPEED  (Read 17671 times)
Re: STURMEY ARCHER 3 SPEED
« Reply #30 on: 04, March, 2013 - 15:36:09 »
Some more work done on the 3 speed c5.Stripped down the motor .Take a look it is in very good condition very little use on it .
As you can see the motor shaft is intact ..
Motor now serviced and running very good
A little more work done .not long now
« Last Edit: 04, March, 2013 - 16:09:59 by C5 ENTHUSIAST + RESTORER »
« Reply #31 on: 04, March, 2013 - 19:02:19 »
Great work there Chas  8)
« Reply #32 on: 05, March, 2013 - 19:35:55 »
More work done .
« Last Edit: 05, March, 2013 - 19:42:42 by C5 ENTHUSIAST + RESTORER »
« Reply #33 on: 05, March, 2013 - 19:40:51 »
It's shocking how quick you can do these  :o 8)
« Reply #34 on: 05, March, 2013 - 19:46:46 »
Just another photo .
« Reply #35 on: 05, March, 2013 - 19:53:45 »
There is still a lot of work to do on the body / wheel trims to get it some thing like . But as always there is a limit to how far you can go .
But this one is in very good condition ..as you will see when it is finished.
 Forgot the mudflaps have been fitted and the brakes coupled up also the Pod is now in place ....
« Reply #36 on: 05, March, 2013 - 20:12:57 »
Amazing
How do you change gear?
« Reply #37 on: 05, March, 2013 - 20:24:42 »
Just a quick pull down on the changer on the right hand side of the handle bar ...
« Reply #38 on: 05, March, 2013 - 20:29:00 »
Great.  I would love to see what it's like.
« Reply #39 on: 05, March, 2013 - 20:37:09 »
Where do you live .
« Reply #40 on: 05, March, 2013 - 21:04:33 »
Ok if you don't want to let me know on the forum you could email me if you want .
otherwise just leave it ...
« Reply #41 on: 05, March, 2013 - 21:15:58 »
Me.  I live north of Manchester. Oldham!  I am presuming the same place the batteries were made!
« Reply #42 on: 06, March, 2013 - 20:29:23 »
Hi sorry to far away for me to see you .
Anyway here are some photos of the boot .....After giving the body a good clean ..nerly there .
« Last Edit: 06, March, 2013 - 20:42:32 by C5 ENTHUSIAST + RESTORER »
« Reply #43 on: 08, March, 2013 - 18:21:40 »
Did a little work on the C5 today ..(3 Speed sturmey archer)
Fitted a horn (not a lot to see only the conection block all the other wires have been placed in the tube )
Replaced the front bulb to a LED bulb ,very bright ..
Front stickers fitted
New 18mm belt fitted
Boot put in place looks great .
At the moment all seems to be ok and working .(not sure if I will fit any mirrors yet)
Things to do clean and fit front wheel covers .
Still needs another clean inside and out .
Then a run out to test everthing is working as it should  ...
Then on Ebay for sale .
As the next one will be started very soon ...
« Last Edit: 08, March, 2013 - 18:50:59 by C5 ENTHUSIAST + RESTORER »
« Reply #44 on: 09, March, 2013 - 15:51:18 »
Hi there .
Front + back wheel covers cleaned and are now ready for fitting ..
