C5Alive General Category > Forum Guide
New restoration May
C5 ENTHUSIAST + RESTORER:
[size=8][/size]This is my next restoration using my Front and Back brake mods as you will there is only a body to start with .I won it some time ago and stripped it down compleat and stored it until now [/color]
R
Just checking the wiring
Found a few bad connections now all seems to be ok Also fitted one of my Warning Hazard light fittings ..as you can see
Fitted a Pod and it seems to be ok but it will need a proper test later on
Thanks this one has got a very good body (very little damage ) and I have seen loads of body's in the past and this one is in great condition
Chassis ready for building up
And here are the brake mods that I will be fitting
Back to today's restoration .started to build up the chassi
[biggrin] [biggrin] :-({|= W:-({|= \:d/
A little more done on the chassis
Body and chassi ready to put together ...Now to sort out the wiring
Started sorting the wiring .also fitted motor + large cog
Navigation
[0] Message Index
[#] Next page
Go to full version
