Author Topic: Cheap batteries !  (Read 8533 times)
marcdonnelly
Re: Cheap batteries !
« Reply #15 on: 29, May, 2010 - 08:46:24 »
Yep i would like 2 for the the royal run if you could confirm these batterys take the orignal sinclair battery top thanks.
« Reply #16 on: 29, May, 2010 - 08:54:52 »
Sorry, but they don't fit the Sinclair battery cover, they are standard car batteries 063 and the slightly bigger 065. I ditched the original key switch arrangement a couple of years ago and use Karl's C5 Alive wiring, as I wanted to use Charlie regular so I have kept the original switch and wiring in a box.
« Reply #17 on: 29, May, 2010 - 08:58:03 »
Ok Marty and Mike, are you both coming on the Royal Run ?
« Reply #18 on: 29, May, 2010 - 11:03:22 »
Yep I'll be there :)
« Reply #19 on: 09, June, 2010 - 07:50:38 »
All being well we will be there  8)
« Reply #20 on: 15, June, 2010 - 20:47:17 »
So if I'm right thats 5 batteries ? please confirm if they are still required, many thanks.
« Reply #21 on: 15, June, 2010 - 23:23:49 »
Hi there ....
I still want one (065)
« Last Edit: 15, June, 2010 - 23:30:10 by PLOD11 »
« Reply #22 on: 16, June, 2010 - 13:52:10 »
I'd still like 2 65s please :)
« Reply #23 on: 17, June, 2010 - 14:38:54 »
Hi Andy - Could you save me two 063's please mate .
See you at the Royal Run  :)
« Reply #24 on: 17, June, 2010 - 21:50:00 »
No worries Karl, will have the brake disc's and pads for the AX if you would like them still ? see you then.
« Reply #25 on: 30, March, 2012 - 09:36:43 »
Just wanted to give an update of my use of these batteries
I ended up buying 3 of these.
2 in the C5s. Sadly, these died over the winter because I forgot about them after I moved house. Well, the kinda do work now but dont hold a charge that well :(
The third has been running my friends 1.6 Megane for the past year + with NO ISSUES WHATSOEVER
Absolutely awesome mate. Thanks again.
« Reply #26 on: 30, March, 2012 - 09:54:01 »
Your most welcome, glad they done the job
« Reply #27 on: 30, March, 2012 - 15:39:22 »
Can you still get these Andy ? - My battery collection is very tired to say the least !
Marty
« Reply #28 on: 31, March, 2012 - 09:37:03 »
I will find out what we have in stock and price's then update this post Marty.
« Reply #29 on: 01, April, 2012 - 07:30:51 »
Thanks Andy  :)
