Author Topic: battery charger  (Read 3617 times)
Offline mark44
battery charger
« on: 26, April, 2011 - 18:36:10 »
hello folks i am after an original charger for my c5,cosmetically good and working too. also i am using a halfords 038 type battery with the original key switch but after a full charge i can only do about half a mile and it dies,it was brand new but didnt seem to like being charged with a sinclair charger that used to work on a battery that came with my c5 from adam harper  many thanks  mark
Re: battery charger
« Reply #1 on: 26, April, 2011 - 19:45:09 »
Hi there I think that you will have to use a normal battery charger .Sinclair chargers where made for  the Sinclair battery ...and I don`t think it will  work with a normal battery ...
Re: battery charger
« Reply #2 on: 28, April, 2011 - 13:35:38 »
Are you sure the battery is healthy ? I'd get it properly "drop" tested , there is some useful info on this link;
http://www.honestjohn.co.uk/forum/post/index.htm?t=19704
If the battery checks out as ok then you might even have a faulty charger ? I've converted a couple of Sinclair chargers before to use on my 063 car batteries and they were fine;
http://c5alive.co.uk/forum/index.php?topic=383.0
becks
Re: battery charger
« Reply #3 on: 28, April, 2011 - 16:18:22 »
i have one £10.00  + £7 postage  there quite heavy if you want it let me know marc.
Re: battery charger
« Reply #4 on: 14, June, 2011 - 11:31:47 »
Hi Mark,
I have a couple of C5 chargers at the meeting in holland for sale.
You can use it for so-called traction (or semi-traction) battery's.
It is a so called "trickle charger" so it won't be very nice with a car battery.
The original Sinclair battery was a semi traction battery as well.
greetz
