C5Alive General Category => C5 Gallery => Topic started by: vanpeebles on 13, November, 2010 - 16:27:01
Title: The project begins!
Post by: vanpeebles on 13, November, 2010 - 16:27:01
Some pics, away we go!  ;D
(http://www.zen70509.zen.co.uk/c5/before.jpg)
(http://www.zen70509.zen.co.uk/c5/before2.jpg)
(http://www.zen70509.zen.co.uk/c5/after.jpg)
(http://www.zen70509.zen.co.uk/c5/after2.jpg)
It took ages to clean with it having like splashed house paint on it, got half the front done and some of the side, loads left to go. I've been using Surfex HD in water with a plastic scrubbing brush and a used pan scrub.
(http://www.zen70509.zen.co.uk/c5/motor.jpg)
(http://www.zen70509.zen.co.uk/c5/wiring.jpg)
The motor doesn't seem connected properly into the clips? With the motorpart being brown and the gearbox being lighter in colour. The wiring is all hacked about, as is the control box. I've took the whole lot off.
If you pedal with both wheels off the ground, do both wheels turn? The right hand side wheel seems a bit tight in places and doesn't turn when you pedal. Although is fine on the ground, possible stuck on brake I guess.
Title: Re: The project begins!
Post by: PLOD11 on 13, November, 2010 - 17:15:12
Its looking good, 25 years of dirt and grime there ..... :D
Getting the C5 back to a useable state is the best bit about owning a C5.
Its well worth all the effort  ;D
John PLOD11
Post by: vanpeebles on 13, November, 2010 - 17:44:24
I bagged one of your DVDs too!  :)
Post by: PLOD11 on 13, November, 2010 - 18:45:23
POSTED THIS MORNING. ;)
Post by: Karl on 13, November, 2010 - 19:16:41
Good progress on the c5 mate - well done !
Post by: C5 ENTHUSIAST + RESTORER on 13, November, 2010 - 19:55:09
Hi there just had a look at your motor and the gearbox seems to have been put back wrong there is a keyway on the gearbox and it does not seem to be used .That's properly why the motor is upside down  ??? but not sure clean it up first then take some more photos of it bye Chas
Post by: PLOD11 on 13, November, 2010 - 21:02:06
You are are Right, it doesn't appear to have anything holding it in, the way that has been put back.  :o
Won't have any problem taking it apart  ;)
Post by: Karl on 14, November, 2010 - 09:31:56
With all the heat sensors missing and the wiring tampered with, going for a "relay" conversion might be the simplest route. If the pod and control box are salvageable they could then be sold on to bring in some funds for other stuff.
Post by: marcdonnelly on 14, November, 2010 - 11:20:22
if you need a overheat sensor drop me a reply thanks marc.
Post by: techytype on 14, November, 2010 - 11:33:28
Just to answer one question, when you peddle/drive only one wheel gets the drive (motor side), the other wheel is free spinning, but may still turn depending on the amount of friction in the bearings, but there will always be some 'drag'.
Alan
Post by: Retro Andy on 15, November, 2010 - 06:46:51
It really is a good feeling getting your C5 back on the road, cleaning everything and making it feel wanted again  :)
Post by: vanpeebles on 15, November, 2010 - 08:15:42
Cheers for the comments everyone. What does a relay conversion consist of? I think I'd like to restore it to original condition but I'd like to know all the options.
Post by: techytype on 15, November, 2010 - 13:32:53
Relay conversion simply dispenses with all the electronics and safety. The relay selected needs a decent current capability, I'd suggest 70 - 100 amps because of stall current pulled., using the small switch to operate the relay and pass the current.
Tbh if your not to sure about the basics then seek help or don't do it, or you could easily have a fire or other nasty accident.
Your one of 'us' now sonprecious, and plenty of help on here to be had :).
Alan
C5 bits come up all the time on eBay, so a nit if patience all will be well.
Alan
Post by: Karl on 15, November, 2010 - 14:58:12
I've built a couple that run on a relay instead of the original control box and pod. You can build in some thermal protection for the motor by using the existing sensor that fits on the flattened part at the bottom of the motor casing near the brushes. I also fit battery monitors to the "dead" pod housing - all the spare innards go to radiomarty for recycling  8)
http://c5alive.co.uk/forum/index.php?topic=1208.0
http://c5alive.co.uk/forum/index.php?topic=1273.0
They are quite simple to set up and really reliable.
Post by: vanpeebles on 20, November, 2010 - 18:39:53
Rained all day today :( I just wanted to go outside and tinker  :'(
Post by: PLOD11 on 20, November, 2010 - 23:19:49
Go out side ?  :o
Bring it indoors,  whats the matter with you   ;D
Post by: Karl on 21, November, 2010 - 17:03:35
Go out side ?  :o
Exactly - thats why we have a dining room table, perfect for placing a c5 on  ;D
Post by: techytype on 21, November, 2010 - 20:32:42
i now have a vision in my head of a C5 straped to a lazy suzzy  ;D
Post by: vanpeebles on 22, November, 2010 - 21:37:41
I've already got the house cluttered up with mini parts and Sinclair QL bits. I think I'd be thrown out if I brought the C5 in!
The other day I was cleaning up the rubber work bits in the house, and someone must have used boot polish on the rubber caps that go where the hi-viz mast goes. The water in the bucket was coal black!  :D
Post by: techytype on 22, November, 2010 - 21:45:23
Just having another vision, of a lazy suzzy strapped to a c5, now that's a way of getting a c5 smile ;).
I must seek therapy :) :) :).
Alan
Post by: vanpeebles on 27, November, 2010 - 19:32:21
(http://www.zen70509.zen.co.uk/c5/c5snow.jpg)
Sky has fallen  :'(
(http://www.zen70509.zen.co.uk/c5/c5bits.jpg)
I gave these a good wash with my degreaser then used some gummi pfledge to keep the rubber bits soft and in nice condition.
Post by: vanpeebles on 26, March, 2011 - 18:36:54
(http://www.zen70509.zen.co.uk/c5mar2611.jpg)
Still on with the cleaning.
Post by: Karl on 26, March, 2011 - 22:13:01
At least the snow has now gone  ;D
Looking good though mate  ;)
