Steve (on the forum as "creepycrawley") said he would like to see his C5 given some TLC. He has used it on most of the c5alive runs and meetings and has always been a big supporter of c5alive. He is always helping out with the large bus we use to carry all the display stuff to the various car shows etc.
I've spent a few afternoons stripping the c5 down to see what needs doing ;
His c5 is in pretty good shape considering the use it has had, the only snags found so far are;
a split in one of the front chassis mounting points
bent rear brake lever
bent bolt on the rear "hoop frame"
rear axle bearing fell apart (the one that sits within the round plastic casing)
..and both the wires from the motor brushes are blue
There's a few other small bits and pieces to sort, but hopefully it will be back up together in time for the MGFest.
