Author Topic: Bike chains  (Read 3814 times)
Bike chains
« on: 05, September, 2010 - 20:36:47 »
I needed a new chain for "Malcolm" (the fur covered C5) so went along to Halfords and got two of these ;
..I've used them before on a couple of c5's and they're not too bad. A close fit to the original spec and not too expensive.
The pitch size matches the figures on the tech spec;
 http://c5alive.co.uk/forum/index.php?topic=1129.0
The chain on the left is the new replacement that I used, the middle chain is the old original Sinclair item and the one on the right is one I tried that is just a bit too small !
You do need a chain breaker to help you remove the excess after joining the two chains , and a set of grips/pliers to push the joining link together  - but no other tools are needed.
« Last Edit: 05, September, 2010 - 20:40:33 by BooBoo »
Offline alan1310
  • i wish i was that man
Re: Bike chains
« Reply #1 on: 15, September, 2010 - 11:08:54 »
cool how much
Re: Bike chains
« Reply #2 on: 15, September, 2010 - 12:14:52 »
Less than £20 for both, about £7 each ? Does include the joining links etc.
