Author Topic: Rear indicator lense template  (Read 3076 times)
Offline POZE
« on: 25, April, 2011 - 09:06:02 »
Hi
Does anyone have a link to a copy of the rear indicator template ?  I see in the instructions to fit the indicators that there should be a template for the rear  to use.
Also , any photos of the spring clips to hold the front and rear lenses on with?  I'm also missing these.
Cheers, Poze
Offline Pyrasanth
Re: Rear indicator lense template
« Reply #1 on: 25, April, 2011 - 12:40:50 »
Hi Paul,
Is this what you mean -
I'm not sure there was a paper cutout for the back
Cheers
Gary
Offline POZE
« Reply #2 on: 26, April, 2011 - 09:47:51 »
Cheers Gary, good pic, nice one!
I dont have the instructions on me, but i thought it said that there was also a rear template and to use this, i'll have a look, but i think it will be very easy to just cut one out myself, i'm keen to get it spot on when i drill the holes etc.
Its also interesting to see these spring clips, i need to get some or something similiar, i have nothing at the moment to secure the front or rears. If your aware of anything i can buy of ebay/wilkinsons etc, let me know.
Id like to have a go fitting them this weekend, then i'll get that digital flasher relay and think about wiring them up.
nice one, Poze
« Reply #3 on: 26, April, 2011 - 10:25:24 »
I've just checked out my boxed set of  c5 indicators and there is no paper template for the rear set, just the  "hard" plastic one shown in the earlier picture. The only paper template is for the front set, a copy of all the fitting instructions is on Roy Woodwards site ( www.Sinclairc5.com );
 http://www.sinclairc5.com/acc_inst/acc_inst_indic_page_1.htm
Offline fezza_rs
« Reply #4 on: 26, April, 2011 - 16:05:35 »
Thats why no two c5s have the indicators in the same place!
Offline POZE
« Reply #5 on: 27, April, 2011 - 11:28:21 »
Hey,
So is that plastic thing in Garys photo a template? Ive not got my indicator lenses on me to check.
Im keen to get the fixings spot on.
Also, the instructions say there should be a tool to open out the hole, does anyone happen to have a photo of a complete box set? BooBoo, i suspect you do! little stash or rareties...!
Next up, i still need to locate the spring clips, flasher and then im on the way!
I plan to buy the exact 2mm drill bit later and the 15mm one for the fronts. I want a perfect fitment as ive saved them for so long!
« Reply #6 on: 27, April, 2011 - 11:54:28 »
Hi there I do have the tool for opening the back hole and the template if you want to borrow them just  let me know ..Chas
