Author Topic: Bluebird 24v the pictures as promised  (Read 3332 times)
Offline scott
« on: 27, April, 2011 - 21:13:58 »
here are the photos of bluebird a couple of when i first collected her and the rest of her pimped with 24 volts,please enjoy ;D
Re: Bluebird 24v the pictures as promised
« Reply #1 on: 28, April, 2011 - 13:27:51 »
That's excellent mate, love the dashboard.
I need to test Voodoo out soon after the gearing modifications maybe we should meet up for an impromptu meeting  8)
Offline scott
« Reply #2 on: 29, April, 2011 - 09:54:32 »
Thanks mate:-) perhaps next week we can find somewhere to test them out, we don't want any fires in holland ha ha ha
« Reply #3 on: 29, April, 2011 - 10:42:46 »
Great to see Bluebird back from the ashes !!!!!
wubbert
« Reply #4 on: 13, June, 2011 - 17:57:16 »
I'm planning to do the same....
Can you tell me more about the gearing modification??
Thnx....
Offline Ariablutron98
  • Time Is Money And I Own It
    • WireGamesStudios
« Reply #5 on: 26, February, 2013 - 16:53:46 »
top dog for pimping!
jadodide
« Reply #6 on: 26, February, 2013 - 17:26:52 »
Well done very nice would not say no to it ..
How does the controller cope with the system ...
« Reply #7 on: 26, February, 2013 - 19:24:09 »
 That's quite a transformation! 8)
« Reply #8 on: 26, February, 2013 - 19:25:37 »
Defiantly unique   ;) ;)
« Last Edit: 26, February, 2013 - 19:35:21 by Luke Salsbury »
« Reply #9 on: 28, February, 2013 - 00:25:13 »
Hate to be the "designer" - but that colour is awesome!
Offline scott
« Reply #10 on: 28, February, 2013 - 22:04:35 »
Thanks everyone she is still running ok, the paint has got damaged here and there after a few incidents on the Holland run :-)  the controller works fine and top speed is around 26 MPH but don't know how long the gearbox will last  Ive fitted Brass planetary gears in it and it runs fine but I make sure I don't thrash it to much  only open the throttle up when I've got some good momentum up  I would like to fit a better rear brake system when they go up for sale again  and might change to gel battery's to get a longer range  but not sure if they will . ;D
« Reply #11 on: 01, March, 2013 - 08:14:59 »
Hi there Scot not sure if the one you mean but I do have the rear brake systems .What you get is the disc / caliper and the axle fitting sleeve + a new axle bearing
 as you will see I fit the brake system on top of the alloy plate ..
« Last Edit: 01, March, 2013 - 08:31:01 by C5 ENTHUSIAST + RESTORER »
Offline scott
« Reply #12 on: 01, March, 2013 - 09:32:43 »
Looks fantastic chas  how much are they ? And i will have to see if I can see if I could get a plate made what guage s/steel did u use ?
Cheers Scott  8)
« Reply #13 on: 01, March, 2013 - 10:02:57 »
Hi there Scott the plate is made of aluminium and is 3mm thick ..
Email sent
