Author Topic: Boot Clips.  (Read 2798 times)
Offline frankev
Boot Clips.
« on: 17, May, 2011 - 12:31:16 »
Hi there,
Since I already tried to make my own boot clips from a sheet of plastic, dril a 25 mm hole in it and saw in half at two/thirth of this hole, i never had any problems. Only, sometimes you have to lift your C5 up, and the plastic snaps. Now, accidentally,(on a very old C5) I found this solution for the clips instead. Just buy a couple off these.
Drill a hole through the bootholders, (where you normally expect the clips to be.) and push this pen through, ready!
I'm probably not the first to mention this solution, but I find this a good solid and workable way to go!
greetz
Frank
Re: Boot Clips.
« Reply #1 on: 17, May, 2011 - 12:33:05 »
Superb - another example of "improvise , adapt & overcome "  ;D
I'll move this into the faults and solutions section so it doesn't get lost.
Offline frankev
Re: Boot Clips.
« Reply #2 on: 17, May, 2011 - 12:51:22 »
Tnx BooBoo
Frank
Offline MikeDX
Re: Boot Clips.
« Reply #3 on: 17, May, 2011 - 12:54:03 »
Top Bodge!
What are those clips called?
Offline frankev
Re: Boot Clips.
« Reply #4 on: 17, May, 2011 - 13:24:09 »
Hi Mike,
We call them "verende borgclips". Google translate makes this into "Spring cotter" (does that sounds familiar to you?)
They Sell them at most hardware stores in different sizes. I paid two pounds for 5 off them. I have the 8 cm version.
Otherwise, if you can't find them, let me know, maybe I can post them to you.
greetz
Frank
Re: Boot Clips.
« Reply #5 on: 17, May, 2011 - 15:41:00 »
FANTASTIC IDEA !!  :)
I have lost all mine that i had fitted, so have given up fittimg them. This looks like the a real good solution. ;D
Stop the boot falling off  :o
