Author Topic: Motor Bearing Required.  (Read 3100 times)
« on: 24, June, 2011 - 07:34:10 »
How do you remove/replace the shaft bearing between the motor and gearbox ? Karl said Chas, you might have these in your parts department ?
Re: Motor Bearing Required.
« Reply #1 on: 24, June, 2011 - 14:41:14 »
Hi there Andy do you mean the two small one's at the end of the shaft that go inside the gear box ..??
« Reply #2 on: 24, June, 2011 - 16:10:44 »
No, I need to remove them both, the plastic cog and then the roller bearingwhich locates in the gearbox casing/housing.
« Reply #3 on: 24, June, 2011 - 19:46:13 »
Hi there Andy Regarding removal of the plastic cog They are very hard to remove the last one I did just got damaged and still refused to move ..It sounds like the bearing that is behind the cog has shot it ..There is no easy way of getting it of the shaft ..But if you do I  have the bearings .
Sorry Chas
« Reply #4 on: 25, June, 2011 - 08:25:09 »
Andy - I have some spare armatures, would exchaning it be easier ? I have access to a hydraulic bearing press via a friend who works at a local garage. He uses it ,very carefully, to remove the bearings from the motor armatures and also the rear axles when needed.
« Reply #5 on: 25, June, 2011 - 08:36:45 »
Thanks, Chas & Karl I think I might go the exchange route, but I hate something get the better of me  >:( I want to try, but don't like the thought of breaking it.
« Reply #6 on: 25, June, 2011 - 09:00:39 »
Well I did it,  :) as I said I didn't want it too win, so just used the press at work and easy job done, will contact you Chas about some new bearings and see how it works when complete.
« Reply #7 on: 25, June, 2011 - 13:35:17 »
Well done Andy ..I may ask you to do a few for me one day ....
Chas
« Reply #8 on: 04, August, 2011 - 06:29:02 »
Do you have the bearing on the shaft of the motor Chas ?
« Reply #9 on: 04, August, 2011 - 08:00:39 »
Hi Andy not sure what bearing you want please let me know ...bye Chas
« Reply #10 on: 05, August, 2011 - 06:29:11 »
Hi Chas, will take some pictures and post on forum, many thanks.
« Reply #11 on: 10, August, 2011 - 07:36:27 »
Hi Chas, what bearings could you supply ?
« Reply #12 on: 16, August, 2011 - 06:29:37 »
If you have any of them Chas I will take them with the battery strap, many thanks.
« Reply #13 on: 16, August, 2011 - 07:04:12 »
Hi there Andy I do have some will email you Bye Chas
« Reply #14 on: 22, August, 2011 - 11:32:41 »
Received the bearings and the battery strap, many thanks Chas,
