Author Topic: POD ?  (Read 1387 times)
toastie
POD ?
« on: 08, July, 2011 - 21:16:56 »
hello , i keep seeing the pod come up , i thought this must be the main big white bit but some post seem to point to it not being that , can someone clear it up for me :)
cheers d
Re: POD ?
« Reply #1 on: 09, July, 2011 - 00:01:20 »
The pod is the electronic display panel that holds the led display  :) :)
toastie
Re: POD ?
« Reply #2 on: 09, July, 2011 - 13:29:14 »
nice one cheers , im learning something new every day :)
Re: POD ?
« Reply #3 on: 12, July, 2011 - 10:13:09 »
The pod ;
..located on the underside of the legshield sits roughly level with your knees.
Contains a fragile ULA chip that is a bit temperamental at the best of times but will certainly get fried if you connect your battery the wrong way round  :o (that's why a c5alive wiring kit is a good thing when discarding the keyswitch assembly, the kit has protection against that happening)
You can bodge a c5 to run without one, but it is useful - part of the protective circuitry that prevents over discharge of your battery and overheating your motor.
toastie
Re: POD ?
« Reply #4 on: 13, July, 2011 - 19:05:32 »
cheers :)
