Author Topic: Chain tensioner  (Read 5954 times)
Chain tensioner
« on: 25, August, 2011 - 18:38:50 »
Hi all had a bit of spare time on my hands so I decided to have a go at making a chain tensioner .
Well just finished making one .Take a look at it
The difference is that the one that I have made will not fall off as it will be bolted on with a small nut/bolt
« Last Edit: 25, August, 2011 - 18:42:33 by C5 ENTHUSIAST + RESTORER »
Re: Chain tensioner
« Reply #1 on: 25, August, 2011 - 18:58:14 »
Looks great, well done  8)
This has always been a weak point on the C5
Will these be available to buy ?
Re: Chain tensioner
« Reply #2 on: 25, August, 2011 - 19:42:49 »
Hi Chas, Like normal you have done a good mod.
ps please can you look at your spares section.
thanks
Re: Chain tensioner
« Reply #3 on: 25, August, 2011 - 21:04:04 »
Thats spot on Chas, looks really good, I reckon you can sell a few of them
Re: Chain tensioner
« Reply #4 on: 26, August, 2011 - 10:56:36 »
Chas - if possible , could you make a few of those clip conversions and sell via your section on this site ? As Plod says the standard clips are getting to be a real pain and I could use a few of those myself !
Email me if there's any snags mate  8)
Re: Chain tensioner
« Reply #5 on: 27, August, 2011 - 08:15:57 »
Hi there Karl the clips that fit my tensioner will not fit the original tensioner . But I wll work on one ...
Re: Chain tensioner
« Reply #6 on: 27, August, 2011 - 11:10:51 »
Top job Chas are you going to make a stock and sell them ?
Re: Chain tensioner
« Reply #7 on: 27, August, 2011 - 21:17:09 »
Hi there Marty just started to make a few ,will put some on the site when finished ...Chas
Re: Chain tensioner
« Reply #8 on: 29, August, 2011 - 19:42:41 »
Hi there all just finished making a few ...
The difference with the ones that I have made to the original ones .
Is first of all they are made from aluminum so they are lighter
Also the problem with the original ones is that they have plastic parts that come off and get lost
So I decided to make them so that nothing could fall off so once fitted they would stay on .
Also made the tension tighter so if the chain has stretched it will still work ...(up to a point)
« Last Edit: 29, August, 2011 - 19:48:40 by C5 ENTHUSIAST + RESTORER »
Re: Chain tensioner
« Reply #9 on: 29, August, 2011 - 21:07:04 »
They look really good , nicely finished as well  8)
Re: Chain tensioner
« Reply #10 on: 30, August, 2011 - 09:51:51 »
much better engineering than the original.
Re: Chain tensioner
« Reply #11 on: 30, August, 2011 - 14:00:37 »
Thanks for the comments ...Chas
Re: Chain tensioner
« Reply #12 on: 31, August, 2011 - 07:54:22 »
Hi just put the Chain Tensioners on for sale on the site in the (Chas section)
Offline vanpeebles
Re: Chain tensioner
« Reply #13 on: 31, August, 2011 - 08:52:21 »
Which site is that? I can't find them  :-[
Re: Chain tensioner
« Reply #14 on: 31, August, 2011 - 08:58:16 »
Hi there click on Home on the site ,Then scroll down to the Chas Section and you will see them ..bye Chas
