Author Topic: A world first for a C5?  (Read 1792 times)
« on: 02, May, 2012 - 17:36:36 »
With the new 18mm drive belt & cable tie round the wall that holds the gearbox up that Karl fitted I now get no belt slip when pulling away just using the motor. ;D If I do only use the motor to pull away, will it cause any premature wear to the gearbox or the big drive cog?
« Last Edit: 02, May, 2012 - 20:17:17 by kamilb1998 »
Re: A world first for a C5?
« Reply #1 on: 02, May, 2012 - 17:47:47 »
Hi there Kamilb not sure what you mean but you should never pull away with just using the motor unless you are going down hill . But I would never pull away unless I was peddling ...Regarding wear you will wear out the small cog on the gearbox first ...And that could cost you a lot of money to replace the .....
bye Chas
marra
« Reply #2 on: 02, May, 2012 - 17:49:36 »
Could damage the inner gears I should imagine, but more likely the motor commutator as its close to stall . would definitely with my weight  :-\ :-\
« Reply #3 on: 02, May, 2012 - 18:11:43 »
Chas, what I mean is that I get no belt slip if I use the motor from a standstill. And I was just curious as to whether it could cause any damage to anything even if I don't get any belt slip.
« Reply #4 on: 02, May, 2012 - 20:04:41 »
With the new 18mm belt Chas fitted.....
ahem ??
..not forgetting the large cable tie I fitted at the same time as fitting the drive belt ?
« Last Edit: 02, May, 2012 - 20:06:38 by BooBoo »
« Reply #5 on: 02, May, 2012 - 20:06:31 »
ahem ??
Were you the one who fitted it?  :-[ :-[
« Reply #6 on: 02, May, 2012 - 20:07:08 »
..certainly was  :-*
« Reply #7 on: 02, May, 2012 - 20:09:02 »
..certainly was  :-*
 :-[ :-[ Sorry. Edited the original post now.
