Author Topic: what charger ?????  (Read 1825 times)
Offline Ant
what charger ?????
« on: 02, May, 2012 - 22:26:11 »
Hi everybody
My new battery arrived on Monday and so far im really happy with it, I went for a cheap option as i had just bought my C5 and funds are low, the battery i got is made by "Alphanine" i think or something along those lines and it's from Amazon for only £36 (12volt 44ah).
Problem is i still dont own  a charger and if im honest im hoping to go out for as long as possible at the week end which will probably result in a flat battery before monday.
any suggestions for a cheap compatible charger would be much appreciated !!!!!!
Ant
Re: what charger ?????
« Reply #1 on: 02, May, 2012 - 22:38:03 »
Any 12V car battery charger will do.
I mainly use the original charger, but I also have one of these Halfords chargers and it charges my batteries up fine.
Edited to add:
One of these would do.
« Last Edit: 02, May, 2012 - 22:40:18 by kamilb1998 »
« Reply #2 on: 02, May, 2012 - 22:43:06 »
As Kamil says, any 12v charger should be ok , I've tried the cheap one from my local Lidl and was very happy with it;
http://c5alive.co.uk/forum/index.php/topic,1484.0.html
Offline Ant
« Reply #3 on: 03, May, 2012 - 06:26:08 »
Im just down the road from a lidl i wonder if they still have them ????
worth a look,
Thanks guys.
Ant
« Reply #4 on: 03, May, 2012 - 07:35:50 »
I think most modern chargers will turn to trickle charge once they have reached battery capacity - just avoid the real old ones that can 'fry' batteries ie they give a continuous full charge rate.  :) :)
