I've seen worse
Your biggest headache is being the wrong side of the pond as far as shipping costs , otherwise it would be quite a straightforward rebuild. Obtaining a replacement front headlight can be a bit expensive as they are getting quite rare so the price is climbing accordingly.
From the photo's I think you would need the following if you wanted to restore it to original spec ;
Boot & boot lock (..you might call it a trunk
Control box
wiring loom
Motor & gearbox
drive belt
Rear Wheel , cover and centre cap
Pod & missing pod pin
Pod wiring loom
tube to hold wiring loom (inside of legshield)
bulb holder and cover for rear of the front headlight
front & rear lights
front wheel cover
You've also got a mirror bracket fitted , you'd probably be better of just removing it rather than trying to source replacement mirrors and an additional bracket as mirrors are getting very expensive as well.
Underneath you might want to check and see if a chain tensioner is fitted ?
The damaged indicator lens is a problem in that indicator kits are seriously expensive and very rare .
I have pretty much all of the stuff available so let me know what items you want from the list and we'll see what we can sort out. Probably best to email me
