Author Topic: Colored boots  (Read 1793 times)
Colored boots
« on: 16, November, 2012 - 21:46:17 »
Hi all ;)
What is the difference between the different colored boots. Are the c5 's with the gray boots older then the ones with the white boots? Was it just another accessory? ??? ??? ??? ??? Mine has a gray boot. ;D ;D
Re: Colored boots
« Reply #1 on: 16, November, 2012 - 21:58:59 »
Re: Colored boots
« Reply #2 on: 16, November, 2012 - 22:00:45 »
Re: Colored boots
« Reply #3 on: 16, November, 2012 - 22:14:40 »
Hi Luke,
I general the grey boot was for the mark1 C5 - the first main batch, This was later on changed to a white boot with some minor mods that was done to the C5 i.e. wiring changes, gear box material (brown to cream), etc. The basics are all the same and quite a lot of boots over the last 30 years have been interchanged.
Nowadays it is down to personal preferance and what you get when you buy your C5.
Hope this helps.
Re: Colored boots
« Reply #4 on: 17, November, 2012 - 18:23:09 »
Yes thanks
So mine was probably one of the first batch out unless someone has changed the boot on it  ::) ::) ::) ::)
Offline Phoenix
  • www.PhoenixDriving.org
  • I love my C5
    • Driving lessons Cirencester and Cheltenham
Re: Colored boots
« Reply #5 on: 17, November, 2012 - 18:45:22 »
You can tell when your was born by the number on it
V100050302778
V1000 = Model reference for C5
5 =1985
03 = March
02778 = 2778th produced that month
Re: Colored boots
« Reply #6 on: 18, November, 2012 - 09:00:34 »
Mine dose not have that, so i don't know when it was made annoyingly :'(
Re: Colored boots
« Reply #7 on: 18, November, 2012 - 09:01:29 »
Thanks for the help ;)
Re: Colored boots
« Reply #8 on: 19, November, 2012 - 10:10:45 »
As Lance says, the earlier versions had the dark boots. White was introduced later in response to criticism that c5's were not visible enough in traffic.
