Author Topic: Indicator Fitting Help Needed  (Read 953 times)
Offline pso-buzz
« on: 03, February, 2013 - 20:32:50 »
Hello there
Does anyone have an original template for fitting the indicators I could borrow or buy of them?
I see it had to be cut out of the fitting instructions.
Also on the plastic template for the rear indicators it has written on it 'This line vertical for right side' 'This line vertical for left side'. Does anyone know what this means? Doh. SORTED THIS ONE. I THOUGHT THE REARS FITTED VERTICALLY BUT THEY DON'T.
Also I have only got two metal lock plate fixings for both front indicators, I think I should have four that fit over the prongs.  Has anyone got any spare or do you have any idea of what I could use instead?
I was thinking maybe a very small elastic band wrapped around it. I should imagine if these round clips are pushed on they won't come off again.
Oh and what are the spring clips for? Its says clip them over the retaining feature on each if the fixings on the rear.
Simon
« Last Edit: 04, February, 2013 - 12:58:37 by pso-buzz »
Offline pso-buzz
Re: Indicator Fitting Help Needed
« Reply #1 on: 04, February, 2013 - 12:55:13 »
« Last Edit: 04, February, 2013 - 12:56:54 by pso-buzz »
« Reply #2 on: 04, February, 2013 - 13:22:01 »
I would not worry I don't have any and mine have stayed in place for the last few years.
