Author Topic: STURMEY ARCHER 3 SPEED  (Read 17918 times)
« on: 18, February, 2013 - 14:23:03 »
Hi all here is this the next restoration project that I will be doing although I have made 3 of the same up in the past ...
« Last Edit: 18, February, 2013 - 14:25:31 by C5 ENTHUSIAST + RESTORER »
Re: STURMEY ARCHER 3 SPEED
« Reply #1 on: 18, February, 2013 - 19:05:46 »
Quote
You made up something like that before
« Reply #2 on: 18, February, 2013 - 19:21:53 »
Yes indeed he has my second C5 is one of Chas's Sturmey Archer conversions  :)
« Reply #3 on: 18, February, 2013 - 19:37:14 »
Hi there Radiomarty do you still have it ...(3 speed c5)
Chas
« Reply #4 on: 18, February, 2013 - 19:45:10 »
Yes indeed I do bud  :)
« Reply #5 on: 18, February, 2013 - 19:50:21 »
Thats great .Hope this new one will last as long as yours ..It must be about 3/4 years since you bought it ...
« Reply #6 on: 18, February, 2013 - 20:13:56 »
Possibly 4 years Chas and still going strong - Marty :)
« Reply #7 on: 18, February, 2013 - 20:38:47 »
Yes you could be right ...
Here are some more photos ..
There rear axle cog moved and welded in to place
« Last Edit: 18, February, 2013 - 20:45:07 by C5 ENTHUSIAST + RESTORER »
« Reply #8 on: 19, February, 2013 - 08:14:32 »
I think I'll stay with the 1 speed gear on mine  ::) :P :-[
« Reply #9 on: 19, February, 2013 - 08:16:08 »
I have seen it on a C5 and it looks quite complicated  :( It has 2 chains as well doesn't it  :-\
Offline mhurt
« Reply #10 on: 19, February, 2013 - 08:53:10 »
It's something I'd like to do and whilst I have a rough idea on the process (I've read the sites with it on etc),  there are still a couple of bits I'm not sure of.
As always,  I'll be watching the progress with my jaw firmly dragging on the floor as has works his magic.
« Reply #11 on: 19, February, 2013 - 12:31:15 »
The first one was hard to make ,But after 3 I think I will be ok ....'
Chas
« Reply #12 on: 20, February, 2013 - 15:48:53 »
Just done a little more work on the Sturmey Archer fitting .It may look a little rough at the moment but it will be tided up later after making sure that all fits and it will work
As you will see I have fitted a new bearing and washer + rubber seal on the axle ..
« Last Edit: 20, February, 2013 - 15:51:27 by C5 ENTHUSIAST + RESTORER »
Offline mhurt
« Reply #13 on: 20, February, 2013 - 16:51:01 »
Chas : how easy/hard is it to move the cog on the axle? It's something I never even considered before.
« Reply #14 on: 20, February, 2013 - 17:44:44 »
Hi there it has to be grinded off then moved along and rewelded in place ...
 Both chains now fitted
Now I know all works well now its time to strip it down and clean all the parts then reinstall them
« Last Edit: 20, February, 2013 - 18:15:08 by C5 ENTHUSIAST + RESTORER »
