Author Topic: Side Panel Fitting  (Read 2114 times)
Offline pso-buzz
Side Panel Fitting
« on: 22, February, 2013 - 13:19:33 »
So the side panels!
It says mark a line 20mm from the edge then for the Velcro to that line.  Which side of the line should it be fitted? If you fit it to the outside of the line this leaves the Velcro pretty much flush with the edge, and if you fit it on the other side it is obviously 20mm inside.
The black plastic toggle thing that fits though the pod, does this go in from the front or the rear?
Simon
« Last Edit: 23, February, 2013 - 14:04:12 by pso-buzz »
Re: Side Panel Fitting
« Reply #1 on: 22, February, 2013 - 15:12:29 »
Quote
That goes through the rear of the pod ;) ;)
Offline pso-buzz
« Reply #2 on: 22, February, 2013 - 15:28:57 »
Quote
Thanks Luke
« Reply #3 on: 22, February, 2013 - 19:05:01 »
This is what I mean just to make sure
« Reply #4 on: 22, February, 2013 - 19:54:03 »
Are you sure they're fitted correctly? I have always put my clips in from the front of the POD.
« Reply #5 on: 22, February, 2013 - 19:55:35 »
Could you show me a picture of your's  :-\ :-\
« Reply #6 on: 22, February, 2013 - 20:29:36 »
I found this on the forum and it shows the clips going through the back of the pod  :-\ :-\
Dose any one actually know how they go through the pod  :-\ :-\
« Reply #7 on: 22, February, 2013 - 20:32:23 »
I'm confused  :) ;) :D ;D >:( :( :o 8) ??? ::) :P :-[ :-X :-\ :'(
« Last Edit: 22, February, 2013 - 20:33:56 by Luke Salsbury »
Offline pso-buzz
« Reply #8 on: 22, February, 2013 - 21:26:55 »
Luke.  Have you not stuck the Velcro to the body?
« Reply #9 on: 22, February, 2013 - 21:36:35 »
No, because it won't reach  ::) ::) ::) stupid things  >:( >:(
Offline pso-buzz
« Reply #10 on: 22, February, 2013 - 21:47:19 »
Why won't it reach. I thought the elastic would allow it to move a bit
« Reply #11 on: 22, February, 2013 - 21:56:46 »
I pull and pull on them to try and get them to but they won't.
Offline Dave.76
« Reply #12 on: 23, February, 2013 - 09:11:49 »
Are these original C5 side panels? If so is it possible that over the years the material has shrunk and/or lost some of its elasticity? So now doesn't fit properly.
« Reply #13 on: 24, February, 2013 - 14:36:54 »
I think that is what has happened
