Author Topic: New member in the Netherlands  (Read 6452 times)
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« on: 18, April, 2013 - 06:42:48 »
Hi there,
Being a Sinclair computer fan/collector I just had to have one...
Just picked up this C5 last monday, it is from the first owner and in original condition. According to him the C5 has only been driven a few times round the block and nothing more.
Have not got a chance to check the electronics yet it as there was no working battery available.
I got an original NOS Oldsham battery with it (unused and dry) but after inspecting underneath the (original) caps the plates are badly corroded so I am not going to fill it up)
The accessories are still in the (styrofoam) box: an indicator set and left and right mirrors, never been fitted. Manual and some more paperwork. Even the factory approval sticker is still on the rear reflector.. Original tyres are on and seem to be in pretty good condition, brakes work and I just pedalled a few meters and it runs smooth.
Re: New member in the Netherlands
« Reply #1 on: 18, April, 2013 - 06:45:02 »
Hi and welcome to the forum. If I'm not mistaken I think there is another C5Alive member in the Netherlands.  ;) ;)
« Reply #2 on: 18, April, 2013 - 07:30:53 »
Welcome to the forum  (what a great find)
 bye Chas
« Reply #3 on: 18, April, 2013 - 10:37:17 »
Welcome to C5Alive -sounds like a very nice C5  :)
Offline thedesigntailor
  • designer and C5 newbie
    • GLOW creative
« Reply #4 on: 18, April, 2013 - 12:03:38 »
I think we have a few in the Netherlands now - welcome on board.
Sounds like you have a real gem there!
« Reply #5 on: 18, April, 2013 - 18:37:27 »
Hi and welcome to the forum,
Post so photos of your C5 and accessories before you fit them.
Offline Ton C5
« Reply #6 on: 18, April, 2013 - 19:48:52 »
Hi welcome to the wunderfull world of the C5.
i think i saw your c5 on marktplaats :-) nice one.
if you any help in dutch, let me know.
i am in the Rotterdam area
Ton
Offline BeeAeRTee
  • Look at my website of "Unusual Vehicles"
  • God has 3 wheels...
    • Hottentottententententoonstelling
« Reply #7 on: 19, April, 2013 - 10:24:37 »
Lot af C5's on Marktplaats last months...
Sometimes real cheap and in good condition...
Good luck with it!
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #8 on: 19, April, 2013 - 18:52:12 »
Thanks for the warm welcome, I hope to get the C5 up and running soon.
At the moment I am investigating a suitable battery, maybe a 'cheap' one for initial testing and then one (or two) Optima Yellow Tops when all is working ok.
« Last Edit: 19, April, 2013 - 19:06:43 by gertk »
« Reply #9 on: 19, April, 2013 - 20:14:55 »
welcome to c5alive  8)
your c5 looks like quite a bargain  ;)
« Reply #10 on: 19, April, 2013 - 22:38:56 »
Hello and welcome to the forum, I like the beetle in the picture aswell  :)
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #11 on: 28, April, 2013 - 18:13:04 »
Today I have driven the first meters with the C5!
On a used sealed lead acid 16 Ah battery which was initially flat but after a good night charge with a trickle charger and then a few hours more on a bigger charger it had sufficient voltage again.
Had to connect this battery with some short heavy cables to the original batterylid and mounted the keyswitch.
After turning the key the pod leds came on, front and rear light were OK (seem to have the original bulbs..)
Inflated the original tires to 25 psi and propped the backend up to see if the motor would run without problems: it ran fine.
After checking the brakes functioned ok I pedalled out of the garage and pushed the button and behold: This C5 is alive!
Now just have to wait for a decent battery to come in.
« Reply #12 on: 28, April, 2013 - 20:44:34 »
That's great well done
bye Chas
« Reply #13 on: 05, May, 2013 - 18:09:56 »
Welcome and good luck with your C5.
Show some more photos when you get a good battery.
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #14 on: 06, May, 2013 - 22:22:03 »
You might check the Victron and PBQ battery thread  :)
