Author Topic: CENTER CAPS  (Read 4527 times)
CENTER CAPS
« on: 06, July, 2013 - 18:28:04 »
Hi just had a go at making some center caps what do you think of them As you can see there are 3 clips that keep them fixed in place
They are made from the same materal as the wheel trims .....Chas
« Last Edit: 06, July, 2013 - 18:32:32 by C5 ENTHUSIAST + RESTORER »
Offline C-Star
Re: CENTER CAPS
« Reply #1 on: 02, June, 2014 - 11:09:03 »
These look great, I like how the pattern of the clips matches the reflector pattern on the trims. It seems there were at least 2 different centre cap designs made by sinclair, one flat one like your design and one that stuck out.
Re: CENTER CAPS
« Reply #2 on: 02, June, 2014 - 13:24:18 »
Thanks Chas
Offline Edward Green
Re: CENTER CAPS
« Reply #3 on: 02, June, 2014 - 16:34:28 »
Not bad at all Chas, they look like a good fit. :)
