Author Topic: batteries?  (Read 3190 times)
Re: batteries?
« Reply #15 on: 16, August, 2013 - 07:36:05 »
No problem with the gel charger, I already have one
Re: batteries?
« Reply #16 on: 17, August, 2013 - 07:53:45 »
I get about 12 miles to a charge off one Yuasa 038 battery, you can get them for around £40?
What type of terminals have you got on your battery. They are different to the car battery batteries. How do you connect yours to the battery, or have I been looking at the wrong battery  :-\
« Last Edit: 17, August, 2013 - 07:58:12 by Luke S »
Re: batteries?
« Reply #17 on: 17, August, 2013 - 09:08:22 »
Its a normal car battery and therefore has normal car battery  terminals. I posted about it earlier here http://c5alive.co.uk/forum/index.php?topic=2142.0
Re: batteries?
« Reply #18 on: 17, August, 2013 - 16:35:34 »
How far can you discharge your battery because I know you can't discharge a car battery to far and how long have you had it
Re: batteries?
« Reply #19 on: 17, August, 2013 - 20:57:25 »
I've always stopped using a battery when I got a beep from the POD, I don't know what voltage this is at though. I tend to replace each battery every 6 months or so as I find that, with the mileage I do, the range starts to drop after about 6 months,
