Author Topic: C5 pod wanted  (Read 1178 times)
Offline Trabi1999
C5 pod wanted
« on: 24, November, 2013 - 18:25:15 »
Nearing the end of the restoration on my c5. Put a c5 alive wiring kit on but didn't relies that you need a pod to make it run. So does anyone has  working one for sale  :)
Re: C5 pod wanted
« Reply #1 on: 24, November, 2013 - 18:46:02 »
Hi you don't need a pod to make the C5 go but you will not get any indication of battery voltage and current being used .But you could connect  the temp cut out ...to the wiring kit ..Also you could fit a volt meter  .(That is if you know how to do it ) .
Chas
Offline Carl Gordon
Re: C5 pod wanted
« Reply #2 on: 24, November, 2013 - 18:58:16 »
Hi, I have a pod for sale, £60 delivered, just need to fully test it before I sell,
Offline Trabi1999
Re: C5 pod wanted
« Reply #3 on: 24, November, 2013 - 19:17:34 »
Hi chas   How do you get it to work without a pod. The lights come on but when you press the button nothing happens    Regards Alex
Offline Trabi1999
Re: C5 pod wanted
« Reply #4 on: 25, November, 2013 - 08:12:37 »
Have found a pod now  :)
