Rear Wheel Build Sequence
Started by Umpa, 04, February, 2009 - 16:09:46
Until I get around to having a go at doing the motor, we thought we would have a go down the lane, we have found that the rear drive wheel wont keep tight. If we tighten it up to much the wheel won't turn.
I'm beginning to think there are some parts missing.
Here's some piccies of the rear wheel components on the brake side , minus the wheeltrim and its large retaining washer ;
Here's the drive belt side ;
If the retaining bolt on your drive belt side gets tight and then goes loose again, it may have previously been overtightened and damaged the thread - it is something we've seen before.
#3
thank you !
Looks like I have all the bits. These shims?
Can you tell me where they fit? I have one before the main gear and one after.
Cheers
Ian
Edit
After looking at the picture I see you have layer the parts out in squence. I'll build mine up as you and use a little silicone as a thread glue for the end nut.
Thanks again, your a swell guy.
Quote from: Umpa on  06, February, 2009  - 06:27:43
spot on mate ;) , the picture of all the components laid out on the towel is the correct sequence. The shims go between the wheel and the white drive cog. They are used to stop the drive cog moving about -  which could cause the drive belt to "wander off"  :)
looks like you're making some good progress on keeping another c5 alive - which is excellent behaviour  8)
ps - I've got your email and will sort out a casing for you.
#5
Cheers dude.
Edit :- I intend to bring 'Nelly' to some meets :) so she has to be right.
it would be great to see some more faces at the meetings , so even if yours isnt ready you could always borrow "Dave"
ps - you mentioned in your email about up/down movement of your rear wheel . This shouldn't happen - although the "wheel bearings" are situated further along in the plastic motor mount assembly, the wheel is kept secure by the "star-shaped" nut and "tube" type parts,plus the retaining bolt. There should be minimal play in the wheel , might be worth checking everything is properly "home and adequately tightened.
I am having serious issues with the rear wheel now.  Just went out for a spin (cant go far because of the motor) - but....
The metal tube must have moved up into the wheel some how.  I lost all drive, the main gear was turning but there was no drive.
I checked the nut and it was OK (i put silicone on the threads).  After I removed the wheel I could see that the metal pipe had moved forward and the main gear just sting on the splines.
A roller bearing had fell out. but I found it and put it back in.  That's where the fun started because after I could not put the pipe back though the bearing !!!!!.
I soaked in in penetrating fluid and ran my finger though it for a while, and with a squirt of spray grease & with a little force it when though.
I have fitted it back on and seems to work OK.  I really have to fix this its doing my head in.
It seems there is no support in the back side of the wheel, all the support is on the spines at the front of the wheel, I'm beginning to think that a part of the wheel in missing - like a bush or something.
Could you do a close up of the inside rear wheel for me ? I'll do one with a real camera this time (all pics so far have been with iphone).
I'm a complete and utter idiot !!!!!
Just realsed. I only had the wheel the wrong way arround. Now I see how it works.
Sorry - for the hassle.
mate - welcome to the weird world of c5 ownership  8); joy and frustration in equal measure  ;D
have you downloaded a copy of the unofficial c5 owners manual ?
full of useful info and available free via the download section from the front page of the main website !
http://c5alive.co.uk/downloads2.htm
word format;
http://c5alive.co.uk/pub/downloads/C5-UnofficialServiceManual.doc
pdf format;
http://c5alive.co.uk/pub/downloads/C5-UnofficialServiceManual.pdf
