Author Topic: totally new way to tune the C5..  (Read 1484 times)
Offline SwedenBob
« on: 28, July, 2014 - 18:41:33 »
what u think about these..
scrap the old motor and put 2 " or even 3!" hub motors!!
it would be easy to get 50 + mph .. even more if u want!
just take out the old rear wheels and put new ones with hub motors !
put back the plastic cap and no one will not even notice you have them there!
but.. maybe these have been done already ??
Re: totally new way to tune the C5..
« Reply #1 on: 28, July, 2014 - 19:07:37 »
Offline SwedenBob
« Reply #2 on: 29, July, 2014 - 06:43:14 »
interesting. but i dont get why put it in the front??
isnt better put 2 in the rear wheels?
now there are hubmotors with 3 Kw each !
so a tot of 6 kw is duable!
for the batteri pack. i think the best even if time consuming is to use AA and sold them togheter
we could then make "mats " of batteries to put on the floor
these is the same batteries they use for electric drag bike in the US
Offline jockywilson11
« Reply #3 on: 29, July, 2014 - 15:54:55 »
Just fit two of these, then you can run at 24V and get the power you need. I fitted two to my C5 and the drop in weight made a huge difference over the old Lead Acid one I was using. I have set mine up in Parallel on 12V and it's a huge improvement. I lot less bother than mucking about with AA batteries and solder
http://www.ebay.co.uk/itm/Ultra-Max-12v-20Ah-LiFePO4-18-Hole-Lithium-Golf-Trolley-Battery/120901844487?_trksid=p2045573.c100034.m2102&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D1%26asc%3D24638%26meid%3D8658601136196525305%26pid%3D100034%26prg%3D10326%26rk%3D3%26rkt%3D4%26sd%3D131126084900
Offline SwedenBob
« Reply #4 on: 09, August, 2014 - 19:08:44 »
what is the top speed you get with them?
ill like to travell at least 30 m/h as a modern moped
« Reply #5 on: 09, August, 2014 - 21:56:41 »
I believe the 24v models with the standard motor will do 25 - 30 mph.
Offline SwedenBob
« Reply #6 on: 10, August, 2014 - 12:19:07 »
great
was it a easy fit?
