Author Topic: Motor and Gearbox Bearings  (Read 2034 times)
Offline aceofhearts
« on: 03, November, 2014 - 04:32:13 »
In case anybody needs this information in the future I have just stripped my motor and gearbox and measured up all of the bearings to be re-ordered. If you shop around on eBay a full set can be had for around £12 (including delivery).
Large gearbox bearing x 1
40 x 52 x 7 (6808)
Small gearbox bearings x 2
7 x 19 x 6 (607)
Main motor bearings x 2
12 x 32 x 10 (6201)
Hope this helps some of you out :)
Offline aceofhearts
Re: Motor and Gearbox Bearings
« Reply #1 on: 04, November, 2014 - 20:06:27 »
Here is the information for the two rear drive bearings as well:
Large drive cog clutch bearing
20 x 26 x 26 (HFL2026)
Motor housing bearing
20 x 26 x 16 (HK2016)
