Author Topic: J'ai un C5!!!!  (Read 32806 times)
Offline minimin
J'ai un C5!!!!
« on: 21, April, 2009 - 20:48:57 »
Hello!
After many moons I finally have myself a C5! After searching on eBay, i saw one 10 miles away, and after having missed out on the last one close to home, I made an offer and I picked it up last night  :)
The electrics are all in a box, and have all been serviced by Adam Harper, so should be in good nick. I have never had more people stop me to say hello in one trip. I took it out for a test run today, and was really surprised to see how fast it went, even if I did have a few near death experiences (the brakes broke! :o) but about 6 people stopped me to say how great it was to see one - one person even remembered seeing the launch on the BBC!
Mark
Re: J'ai un C5!!!!
« Reply #1 on: 21, April, 2009 - 20:52:31 »
Superb behaviour mate  ;D
Some really good news !
Offline minimin
Re: J'ai un C5!!!!
« Reply #2 on: 21, April, 2009 - 21:31:53 »
Thanks. Your advice on the brake cable was much appreciated. I will be at the bike shop tomorrow morning! I zipped along on the C5 to the bike shop which was shut!!!! So, just a few questions. First, what is a good way to clean it? Really cleaning it. Its filthy. Also, how do you smooth out holes/scratches?
Mark
Re: J'ai un C5!!!!
« Reply #3 on: 21, April, 2009 - 21:46:38 »
What a great picture, had to be done.
Re: J'ai un C5!!!!
« Reply #4 on: 21, April, 2009 - 21:49:46 »
......So, just a few questions. First, what is a good way to clean it? Really cleaning it. Its filthy. Also, how do you smooth out holes/scratches?
Mark
cleaning ---> http://c5alive.co.uk/forum/index.php?topic=335.0
Offline minimin
Re: J'ai un C5!!!!
« Reply #5 on: 21, April, 2009 - 22:55:40 »
Thanks Karl, will do that tomorrow. It came with the two wheel covers but no centre bit, so do you know if I could buy them anywhere, or am I best of sticking to eBay? Also are the wing mirrors meant to be really bendy?
Mark
Re: J'ai un C5!!!!
« Reply #6 on: 22, April, 2009 - 06:58:57 »
Hi Mark,
I'm really glad you got a C5 they are awesome machines.  I know what you mean about the attention you get on one - people just love the C5.
As for the centre hubs, you might struggle, I was lucky enough to get some, but I spoke to Adam Harper about getting some, and the bad news is they were never supplied as a seperate item, even tho they have a part number, then only come with complete hubcaps.  Adam sells these at 40  quid each, but they are brand new mind.
I think you can buy some non original ones I have seen some somewhere but I'm one of these funny buggers that like original parts :)
As for wing mirrors being bendy - not really the plastic case bends if you wobble them but they should be quite firm.  I got some new ones from adam, and make the thing look fantastic - and they really work too.
Good luck with ya C5 dude
Regards
Ian
« Last Edit: 22, April, 2009 - 07:01:58 by Umpa »
Re: J'ai un C5!!!!
« Reply #7 on: 22, April, 2009 - 14:57:16 »
Mark
Non-original centre caps: http://c5alive.co.uk/ecommerce/product_info.php?cPath=4&products_id=20&osCsid=da37f16164d1637b0d5b6b552e3a77f1
Obviously they look different to the originals, but they still look okay and are a cheap way of improving the look of a c5 if the original centre caps are missing. I've fitted them to one of my own C5's.
The mirrors do flex and wobble , and need to be fitted using the black plastic clips. I suspect these are designed to allow the mirror to unclip on impact without damaging the bodywork.
Re: J'ai un C5!!!!
« Reply #8 on: 22, April, 2009 - 18:16:35 »
I know I had seen em somewhere LOL.
As for the mirrors - mine don't wobble just the bodywork they are attached to.
When I fitted mine I had to drill two holes and they screwed on with the black clips you mention.
I was really impressed by the way you can move the mirrors (like on a car).
Offline minimin
Re: J'ai un C5!!!!
« Reply #9 on: 22, April, 2009 - 19:42:09 »
OK. C5 is cleaned up. It has started to click away!!! But it cant be the motor, because its not yet installed? Any ideas?
Offline minimin
Re: J'ai un C5!!!!
« Reply #10 on: 22, April, 2009 - 19:57:54 »
REVISION.
I've had a look and it is the chain, which makes the noise as it passes under the Chassis, in the middle of the Y. But what can I do to stop the noise? The chain is only new.
Re: J'ai un C5!!!!
« Reply #11 on: 22, April, 2009 - 21:24:49 »
my chain is a pain too,
Usually they jump under load and come off the chain tensioner.
Is that what you mean ?
Offline minimin
Re: J'ai un C5!!!!
« Reply #12 on: 22, April, 2009 - 22:30:31 »
Sort of.... There is no tensioner. It doesn't change when there is a rider or not, but when you push the pedals, you can see it hitting the frame. Also, when there is a leaf (very mechanical) pushing it does click but not so loud. So I suppose I need a big leaf?
Mark
Re: J'ai un C5!!!!
« Reply #13 on: 22, April, 2009 - 22:34:59 »
I dont know what you mean by leaf, there should be a tensioner without it the chain will jump.
Offline minimin
Re: J'ai un C5!!!!
« Reply #14 on: 22, April, 2009 - 22:51:53 »
Right, when you look at the C5 with no motor, through the back, you can see straight forward and the chain, which loops round. There is no sort of tensioner, just a chain and 2 cogs.
