Author Topic: J'ai un C5!!!!  (Read 33418 times)
Offline minimin
Re: J'ai un C5!!!!
« Reply #75 on: 07, May, 2009 - 21:14:21 »
Does your c5 have a partial loom already on it ?
Nope. It has NO wires whatsoever.
Re: J'ai un C5!!!!
« Reply #76 on: 07, May, 2009 - 21:49:51 »
Sorry thats lost me, i only remembered where my wires went because i took pictures, some of them are straight forward, but their are some that's not used unless you have indicators etc.
Re: J'ai un C5!!!!
« Reply #77 on: 08, May, 2009 - 12:45:20 »
Andy - if possible could you either email minimin some piccies or post them here ?
Piccies speak a thousand words so it might be the easiest answer.
Re: J'ai un C5!!!!
« Reply #78 on: 08, May, 2009 - 14:52:59 »
Not sure what ones i have now, but i will have a look.
Offline minimin
Re: J'ai un C5!!!!
« Reply #79 on: 08, May, 2009 - 23:56:12 »
Anyone know how to take apart a C5 lock? Thanks
Mark
Re: J'ai un C5!!!!
« Reply #80 on: 09, May, 2009 - 01:41:17 »
Mark
Not sure ! Do you mean loom ?
Re: J'ai un C5!!!!
« Reply #81 on: 09, May, 2009 - 08:13:07 »
I found this two pictures of the control box wires, hope they help a little, if you have a complete wiring loom, then some of the wires have no connectors on the ends, these are only used for indicators etc, if your c5 does'nt have indicators etc then a lot of the wires are just neatly cable tied away, but the rest should be easy to work out, like the lights, the power switch, pod and motor.
<a href="http://s292.photobucket.com/albums/mm29/retroandy/?action=view&current=phonepics136.jpg" target="_blank"><img src="http://i292.photobucket.com/albums/mm29/retroandy/phonepics136.jpg" border="0" alt="Photobucket"></a>
<a href="http://s292.photobucket.com/albums/mm29/retroandy/?action=view&current=phonepics137.jpg" target="_blank"><img src="http://i292.photobucket.com/albums/mm29/retroandy/phonepics137.jpg" border="0" alt="Photobucket"></a>
Re: J'ai un C5!!!!
« Reply #82 on: 09, May, 2009 - 08:15:34 »
By the way did i just earn another star to my profile Karl for hitting 250 posts ? ;D
Re: J'ai un C5!!!!
« Reply #83 on: 09, May, 2009 - 08:28:53 »
Also have a look at my restoration picture's (type in to the search bar:- Andy's Project) you may find some of these pictures useful, feel free to drop me a message with your phone number and i will call you and explain where the wires go a bit better.
Offline minimin
Re: J'ai un C5!!!!
« Reply #84 on: 09, May, 2009 - 15:37:10 »
Hiya! How long is the front and back break cables, and the Lock thingy was for the boot.
Offline minimin
Re: J'ai un C5!!!!
« Reply #85 on: 10, May, 2009 - 11:35:29 »
Hiya,
Does anyone know where you can get a current shunt.
Mark
Re: J'ai un C5!!!!
« Reply #86 on: 10, May, 2009 - 20:48:02 »
Hiya,
Mark
whats one of them ?
Offline minimin
Re: J'ai un C5!!!!
« Reply #87 on: 12, May, 2009 - 19:50:30 »
Hi Karl,
How long would it take for an order to get to me if I were to order tonight?
Mark
Offline minimin
Re: J'ai un C5!!!!
« Reply #88 on: 12, May, 2009 - 20:38:13 »
Also, how do you get the rear break light off (opened up?)
Mark
Re: J'ai un C5!!!!
« Reply #89 on: 12, May, 2009 - 21:05:34 »
If you mean once the light unit is removed, you cant seperate the rear lense from the grey bulb holder back part, the light is one moulded unit.
