Author Topic: J'ai un C5!!!!  (Read 27117 times)
Offline minimin
Re: J'ai un C5!!!!
« Reply #105 on: 14, May, 2009 - 21:39:21 »
Scott, I'll give you a call tomorrow mate.
Mark.
Offline minimin
Re: J'ai un C5!!!!
« Reply #106 on: 18, May, 2009 - 22:55:27 »
How long is the chain?
Mark
Offline minimin
Re: J'ai un C5!!!!
« Reply #107 on: 19, May, 2009 - 21:36:56 »
Also, has anyone got the two lugs that hold the light on? And also a boot lock and key?
HELP ME  ;D ;D
Mark
Re: J'ai un C5!!!!
« Reply #108 on: 19, May, 2009 - 21:47:50 »
I think the chain was 182 links i think ? I did count them, but it was about five weeks ago when i replaced mine.
Offline minimin
Re: J'ai un C5!!!!
« Reply #109 on: 19, May, 2009 - 21:52:48 »
Thanks. Also, was wondering if anyone has the bolts for the pedals, or any sort of instructions for putting the pedals back on.
Mark
Re: J'ai un C5!!!!
« Reply #110 on: 19, May, 2009 - 22:00:09 »
HELP ME  ;D ;D
Mark
Not exactly sure what you mean  ??? If you are talking about the front light, the lugs are attached as part of the light unit itself - if they are missing then the light is broken.
The rear light has two screws and a "lip" along the bottom edge.
« Last Edit: 19, May, 2009 - 22:01:41 by Karl (C5Alive) »
Offline minimin
Re: J'ai un C5!!!!
« Reply #111 on: 19, May, 2009 - 22:27:01 »
Those black things at the top. And this picture is by Leeb.
Mark
Re: J'ai un C5!!!!
« Reply #112 on: 20, May, 2009 - 06:25:38 »
I don't see a picture
Re: J'ai un C5!!!!
« Reply #113 on: 20, May, 2009 - 10:06:26 »
I didn't see a picture before, but I do now !
Offline minimin
Re: J'ai un C5!!!!
« Reply #114 on: 21, May, 2009 - 19:45:28 »
OK. The C5 is on the brink of running, all thanks to the wonderful Scott!!!!!  ;D ;D But how do I connect the motor to the battery? I have the battery block, but what else do I need wire-wise? Also, how do I connect the rear light?
Mark
Offline scott
Re: J'ai un C5!!!!
« Reply #115 on: 21, May, 2009 - 20:01:22 »
mark i think your probally best off buying a c5 wiring kit as you can use any battery  i've got one and they are really easy to fit you can get one from c5 martin.
C5Paul
Re: J'ai un C5!!!!
« Reply #116 on: 21, May, 2009 - 20:17:18 »
I second that, I got my wiring loom today, fitted it within 20 minutes and connected it to a brand new battery. Was zooming around in minutes!
Offline minimin
Re: J'ai un C5!!!!
« Reply #117 on: 21, May, 2009 - 20:27:31 »
Only problem is they are sold out. So I need some sort of alternative method.
Mark
Re: J'ai un C5!!!!
« Reply #118 on: 21, May, 2009 - 22:04:43 »
Mark
They do tend to sell quickly.
I'm sure Martin will get the next batch sorted as soon as he can but, as always, it's a case of finding the time to fit everything in.
When the next lot is ready I will announce it on the forum.
Offline minimin
Re: J'ai un C5!!!!
« Reply #119 on: 21, May, 2009 - 22:08:54 »
Mark
Yep, thanks Karl. Was wondering what your alternative would be? How do I wire the battery up?
