Author Topic: Rear wheel  (Read 2085 times)
Benniz
Re: Rear wheel
« Reply #1 on: 25, January, 2010 - 14:16:55 »
Looks like a brilliant project! and perfect for a front wheel drive for Offroad use (wink wink) :D
Re: Rear wheel
« Reply #2 on: 25, January, 2010 - 15:34:44 »
It says rear wheel on the advert, I doubt it would fit on the front.
Offline techytype
Re: Rear wheel
« Reply #3 on: 25, January, 2010 - 19:29:16 »
i don't think there would be much of an issue fitting it to a C5 rear, problem would be matching another wheel for the other side  ???.
from what i can see there also seems a largish extension to the hub on the 'far' side of the axle, OK for a bodacious type lady driver  ;D
Henrik Ga
Re: Rear wheel
« Reply #4 on: 25, January, 2010 - 20:05:33 »
what about this wheel hub motor
http://www.goldenmotor.com/hubmotors/hubmotor-12_REAR_MOTOR.pdf
much easy'er to install on the front wheel
Re: Rear wheel
« Reply #5 on: 25, January, 2010 - 20:09:57 »
They have two available, if you want to put one each side ?
Offline techytype
Re: Rear wheel
« Reply #6 on: 26, January, 2010 - 10:00:40 »
it's lucky they reverse Andy - or i'd go around in circles  ::)
fitting 2 motors, i'd need a trailer for the batteries  ;D
Offline techytype
Re: Rear wheel
« Reply #7 on: 26, January, 2010 - 10:03:14 »
others on the forum have installed these type of hub motors, i know there is one make supplying a kit for about £250.00 (uk)
