Bluebird 24v the pictures as promised
Started by scott, 27, April, 2011 - 21:13:58
scott
here are the photos of bluebird a couple of when i first collected her and the rest of her pimped with 24 volts,please enjoy ;D
That's excellent mate, love the dashboard.
I need to test Voodoo out soon after the gearing modifications maybe we should meet up for an impromptu meeting  8)
scott
Thanks mate:-) perhaps next week we can find somewhere to test them out, we don't want any fires in holland ha ha ha
Great to see Bluebird back from the ashes !!!!!
wubbert
Quote from: BooBoo on  28, April, 2011  - 13:27:51
I'm planning to do the same....
Can you tell me more about the gearing modification??
Thnx....
Ariablutron98
C5 ENTHUSIAST + RESTORER
Well done very nice would not say no to it ..
How does the controller cope with the system ...
kamilb1998
Luke S
#8
Defiantly unique   ;) ;)
thedesigntailor
Hate to be the "designer" - but that colour is awesome!
scott
Thanks everyone she is still running ok, the paint has got damaged here and there after a few incidents on the Holland run :-)  the controller works fine and top speed is around 26 MPH but don't know how long the gearbox will last  Ive fitted Brass planetary gears in it and it runs fine but I make sure I don't thrash it to much  only open the throttle up when I've got some good momentum up  I would like to fit a better rear brake system when they go up for sale again  and might change to gel battery's to get a longer range  but not sure if they will . ;D
#11
Hi there Scot not sure if the one you mean but I do have the rear brake systems .What you get is the disc / caliper and the axle fitting sleeve + a new axle bearing
as you will see I fit the brake system on top of the alloy plate ..
scott
Looks fantastic chas  how much are they ? And i will have to see if I can see if I could get a plate made what guage s/steel did u use ?
Cheers Scott  8)
Hi there Scott the plate is made of aluminium and is 3mm thick ..
Email sent
