My next restoration/project will be a 24 volt C5
Started by C5 ENTHUSIAST + RESTORER, 03, December, 2011 - 19:23:47
Hi there sorry I will not be selling any of the motors I need them myself sorry .....Chas
Jonny
Will you be selling any of these 24v conversions?
Regarding the 24v Batmobile going to fast I have had another toothed drive pulley drilled out and fitted to the motor .This one has 24 teeth the old one had 30 giving me a top speed of about 35 mph (to fast) .Now the new one has decreased the speed to about 25 mph and given more torque . I Also increased the acceleration on the controller (There was a delay). Just needs another run out....Photo's to follow ....
They look really good Chas - may put a set on Goldfinger as it only has fronts atm - Marty
Hi Chas how have you got the POD LED's setup are they also working with voltage or current or just as indicators.
I take it the outer amber are battery voltage connected.
#81
Hi there Lance The pod LEDs are just for the indicators if they are on  they will flash Left and right or both if the hazard switch is on  ..But I have fitted one amber on each end as a power indicator ...
If any one is interested in the back indicators here is where I got them from bare in mind they are not flush fitting and the body needs to be cut out ...and I changed the bulbs to led ones ... The other 3 digit LED one's are for the current and the voltage
EBAY No   190599586444
Hi there Dave will get back to you with what you want later today ...
bye Chas
