C5 Motor dead?
Started by USA-C5-Owner, 11, November, 2014 - 17:57:30
USA-C5-Owner
Chas, I will tap the two small bearing down the shaft.  What is the large thin bearing?  Is it the bearing in the outer gear housing?  If so, it is seated properly.
Adam
USA-C5-Owner
Chas,
The motor is now assembled and working properly.  The top shaft has a slight wobble (slight bend) but it seems to have no ill effect as the outer gear housing still fits over the top and I can still spin the motor by hand.  So I expect it to be fine.   Thanks again for all the help and for not giving up on me with this.
And Chas, Merry Christmas.
Hi there Adam that's great well done .Whats the next thing I would like to help again
So contact me anytime
Bye Chas  :) :) :)
USA-C5-Owner
Thanks again Chas, I couldn't have done it without you!   :D
