HELP !! Bearing smashed
Started by Umpa, 12, March, 2009 - 12:41:10
I had a squeaky rear wheel, thinking it was the shoes I took the wheel off. The bearing race was smashed and all the little balls dropped out.  So I stuck them in with greas (minus the race) and added a few more from another (propper) bearing I had, the balls were the same size.  I ended up putting 12 in leaving space or 1/2 or 1 ball.
Will this be ok or am I screwed ?
Cheers
Ian
Thanks Martin,
Will I be OK with twelve till the meet ?
well it got me to work ok on 12 so I guess it's enough. Wheel stopped squeaking to so it must have been the wheel not running true that was causing it.
Panic mode over LOL.
Thanks.
