Author Topic: C5 PROTOTYPES  (Read 5762 times)
C5 PROTOTYPES
« on: 09, May, 2010 - 14:53:25 »
Check out my c5 prototypes
Light green gearbox outer case
« Last Edit: 09, May, 2010 - 15:18:27 by C5 ENTHUSIAST + RESTORER »
Re: C5 PROTOTYPES
« Reply #1 on: 09, May, 2010 - 16:51:04 »
CONTROL BOX PROTOTYPE
Re: C5 PROTOTYPES
« Reply #2 on: 09, May, 2010 - 21:18:57 »
Some intresting stuff there Chas - I have always wondered about the Sinclair prototype stuff - I used to work for GM and was involved with a lot of the prototype manufacture but it always got crushed after reaching the next level - good to see some stuff from Sinclair is still about.
« Last Edit: 09, May, 2010 - 21:24:11 by radiomarty »
Re: C5 PROTOTYPES
« Reply #3 on: 10, May, 2010 - 11:28:10 »
Yes you are right when they get want they want the prototypes are just thrown away ...
but as you can see I do have a few items that have been saved ..
« Last Edit: 10, May, 2010 - 11:41:51 by C5 ENTHUSIAST + RESTORER »
Re: C5 PROTOTYPES
« Reply #4 on: 10, May, 2010 - 15:06:07 »
Fascinating stuff - good to see they've been saved  8)
marcdonnelly
Re: C5 PROTOTYPES
« Reply #5 on: 10, May, 2010 - 23:42:08 »
hi there....with the key switch...one of my c5 has that type of keyswitch fitted to it...lol....but the rest are the other type...
neil
p.s intresting stuff mate
Re: C5 PROTOTYPES
« Reply #6 on: 12, May, 2010 - 08:54:08 »
Another prototype found wing mirror brackets .No L/R on them + take a look
Re: C5 PROTOTYPES
« Reply #7 on: 23, April, 2011 - 17:22:51 »
JUST FOUND A PROTOTYPE OF THE BACK BRAKE TO ADD TO MY COLLECTION
Re: C5 PROTOTYPES
« Reply #8 on: 28, April, 2011 - 17:10:05 »
ANOTHER PROTOTYPE OF THE BACK BRAKE WHEEL WITH NO HEAT SINK PLATE ..(NEEDS A CLEAN  ...)
Re: C5 PROTOTYPES
« Reply #9 on: 28, April, 2011 - 17:13:19 »
HERE IS ANOTHER ONE THIS ONE IS THE MOTOR MOUNT BRACKET WITH AND WITHOUT THE MOTO SUPPORT ....AND ALSO THE 6 PINS THAT HOLD IN THE BEARING/WASHER
« Last Edit: 28, April, 2011 - 17:48:04 by C5 ENTHUSIAST + RESTORER »
marra
Re: C5 PROTOTYPES
« Reply #10 on: 28, April, 2011 - 19:38:33 »
Hey my C5 has the smaller rear wheel plate fitted, I never new it was a proto, have another in a tub also spare. I think I will change it over to the bigger one as I didnt realise it was a heat sink. ta for heads up.
Re: C5 PROTOTYPES
« Reply #11 on: 29, April, 2011 - 08:09:10 »
Where do you keep finding these prototypes Chas ?
Re: C5 PROTOTYPES
« Reply #12 on: 29, April, 2011 - 11:21:30 »
If he tells you, he will have to kill you....    ;D
