Author Topic: had a try with one of these betteries  (Read 7737 times)
marra
« on: 31, August, 2010 - 19:07:16 »
bought one of these from flee-bay. I got a battery top given off a mush when i bought a pod from him, so as it cost me nothing I chopped and cropped it to fit. Charged about 5 times and doing good. Only seem to be getting about 15 miles though  :-\ . According to the C5 manual on a battery half this size I should be getting that anyway. Oh well, for what I paid it isnt bad. Marra
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140438531116&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D140438531116%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
Re: had a try with one of these betteries
« Reply #1 on: 31, August, 2010 - 19:19:03 »
Never mind the manual i'm thinking 15miles is very good - would be interesting to know how it keeps performing over time -Thanks for that.
marra
« Reply #2 on: 31, August, 2010 - 19:44:37 »
So 15 miles on 76 ah is good, I was looking at getting a 110 ah  ;D ... pretty heavy though  :( May get another one of these .... more miles then.
« Reply #3 on: 31, August, 2010 - 21:46:22 »
What's the weight of that Marra? Can you bung it on the scales for us?
« Reply #4 on: 31, August, 2010 - 22:07:33 »
The advert says.... "Weight approx 27.5 Kg"  :-*
marra
« Reply #5 on: 31, August, 2010 - 22:47:33 »
Mine showing 29.5 - 30 kg.
« Reply #6 on: 01, September, 2010 - 07:52:59 »
That is quite heavy, doubt you could run a 24v using two of those as I'd be worried about the chassis.
Not a problem though if you're sticking with 12v and carrying just the one battery.
marra
« Reply #7 on: 01, September, 2010 - 08:56:34 »
You are right, If I go 24 then prob just buy a couple of car lead acid ones like recommended on earlier threads. This one seems to be good as its lighter than 2 x 36/38 ah ones that I have seen, but getting the same ah's.
« Reply #8 on: 01, September, 2010 - 08:57:30 »
The advertised weight for the battery is obviously prior to charging.It weighs significantly more when full of electricity!!!!.
« Reply #9 on: 01, September, 2010 - 08:58:57 »
Actually, my 45Ah car battery weighs only 12.5Kg.
marra
« Reply #10 on: 01, September, 2010 - 09:07:16 »
They sound to be better then, what type are they ? Only thing with that I would have to buy another charger. suppose they cheap enough anyway.
Rickvalet
« Reply #11 on: 22, September, 2010 - 16:59:04 »
Hi, I splashed out and bought a Ping battery off Ebay. Ping builds them to your spec and they are Lifepo4.
Battery spec
Lifepo4
12v
40 Ah
Weight 5kg!!!!
The Results?
Well I get about thirty miles from a charge and you really notice the 10kg weight saving. I Pulled the guts out of the Oldham battery and put the new one inside so it looks original and retains key.
These new Ping batteries really are superb.They cost £350, but will outlast the life of a lead acid more than eight times over.    :)
« Reply #12 on: 22, September, 2010 - 20:01:32 »
£350    :o
Offline mike7201
« Reply #13 on: 22, September, 2010 - 21:05:11 »
That's exactly what I was thinking!   :o  :o  :o  :o  :o
A bit like the printer being cheaper than the ink.  In this case, you could get another C5 for £350!!
« Reply #14 on: 22, September, 2010 - 21:33:49 »
i was thinking more about doing 30 miles in a C5  :o, what 'numb bum' time that would be  ;D
Alan
