C5alive Marketplace => The Chas section => Topic started by: C5 ENTHUSIAST + RESTORER on 05, July, 2012 - 22:57:58
Hi all Just Started a new restoration and conversion on a C5 to 24 volt Photo's to follow
Hi Chas,
Like normal looking forward to seeing it.
oooh 8)
Hi all just stripped down the C5 it's on youtube check it out .....When it was brought it looked ok but as you can see it's in a mess and needs a restoration ...Also started to rearrange the wiring and going to have some base plates cut out .You will also see that the main frame and the back arch have been sanded down and painted ...
http://www.youtube.com/user/JORDAN8ISH?feature=guide
bye Chas
I have one in also with challenging wiring ! - look forward to the finished results Chas :
(http://i920.photobucket.com/albums/ad49/radiomarty/20120706_174752.jpg)
Ps notice the bracket welded to the LH side of the rear 'hoop' No idea what it was for ? ???
Marty
Hi there Radiomarty you have your work cut out there ....
Hi there here are some more photo's of the restoration+convert to 24volt
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2285.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/4-IMGP2293.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2291.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2290.jpg)
Are they the CityJet replacements? Blooming sexy tires!
Hi there they are City Jet tires ...
Just a couple of photo's on the C5 conversion ..Checking out the holes for the bolts and the cut out for the cog ...The axle in the photo is not the one that I will be using Its down for the fitting of the disc brake and a new bearing ...Also fitted a fan to the new motor that I will be using .
(http://i992.photobucket.com/albums/af46/jordan8_2009/th_3-IMGP2298.jpg) (http://s992.photobucket.com/albums/af46/jordan8_2009/?action=view¤t=3-IMGP2298.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/th_6-IMGP2323.jpg) (http://s992.photobucket.com/albums/af46/jordan8_2009/?action=view¤t=6-IMGP2323.jpg)
Just done a little work on the C5 24 volt ...Also just made up a 24 volt safety cable with higher amp cables and smaller cables for 12 and 24 volt out puts so you can run the lights/indicators horn and the fans on 12 volt.....
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2329.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/4-IMGP2334.jpg)
Here are some more photo's of the build up ..
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2343.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/4-IMGP2345.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/5-IMGP2346.jpg)
The wiring has now been completed after adding another fan ..
Tested the UNI 8 24v CONTROLER and it works a treat ,,
(http://i992.photobucket.com/albums/af46/jordan8_2009/7-IMGP2349.jpg)
Here is a small video of the C5 ..Just fitted a hazard flasher ..
(http://i992.photobucket.com/albums/af46/jordan8_2009/th_1-IMGP2351.jpg) (http://s992.photobucket.com/albums/af46/jordan8_2009/?action=view¤t=1-IMGP2351.mp4)
Just finished the 24 volt all it needs is 2 new Batteries and a good run ...
(http://i992.photobucket.com/albums/af46/jordan8_2009/4-IMGP2358.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/3-IMGP2357.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/2-IMGP2356.jpg)
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-IMGP2355.jpg)
Now that I have finished this restoration / conversion to 24 volt . I have just collected another one to do the same for Paul .Only this one has no indicators and mirrors .at the moment ....
Photo's to follow ...Chas
Great job Chas - think maybe the 24v jobs will be keeping you busy :) :)
Nice one Chas, I am sure Dave will be happy.
Looks good Chas. If i get stuck when it comes to doing a 24v, i might have to give you a call.
Any time no problem ...bye Chas
Wow that was quick!
Received the new batteries Yesterday and took it for a run of about 5 miles and all went very well I'm very pleased with it ...
Take a look at the photo collage
(http://i992.photobucket.com/albums/af46/jordan8_2009/1-24VOLTWIRINGCOMPLETED.jpg)
So onwards and upwards as soon as Dave can collect this one the sooner I can start the next one ..(I have done a little already )
Photo's to follow ..Chas
