C5Alive General Category => Welcome To The Forum => Topic started by: malfunction on 14, April, 2013 - 03:29:52
Hi , My name is Malcolm and I am a C5aholic.
The last (and first time since I was a kid) time I rode a C5 was yesterday.
I have been looking of a C5 for a while, and met a guy with some to restore. One of which will be mine.
My progress restoring the C5s is documented here. http://malfunction.faed.name/search/label/C5 (http://malfunction.faed.name/search/label/C5)
I am almost done identifying what parts I will need and will need to go shopping. ;)
I look forward to 'meeting' you here..
Malcolm.
Welcome to the forum ;) ;) ;) ;)
Welcome Malcolm any help you want just ask ....bye Chas
Hi Malcolm
I see you are from Australia - welcome! ;D
Hello Malcolm
Welcome to the forum and good luck with your C5's.
Dave
Hello and welcome to the C5 Alive forum, Please post us some sun shine this way :)
Welcome to the forum - enjoy :)
glad to have you aboard mate 8)
Not sure of the best forum for tech notes, but here is some data on the motor and gearbox components.
C5 drive components
Planetary gearbox output drive pulley:
- Diameter ~31mm
- 21 tooth
Axle Drive pulley:
- Diameter ~107mm
- 68 tooth
- One Way Bearing INA HFL 2026
Drive Belt:
- Length = 400mm
- Width = 18mm
- Teeth = 80 tooth
- 5mm Pitch
- Megadyne Isoran 400 RPP5
- Local .au equivalent - 400-T5 80 400.0 from http://www.naismith.com.au/catalogues/pulleys/metric.pdf
Final ratio = 21/68 = .308 or a 3.23 reduction.
Replacement Aluminium Pulleys from Naismith in Sydney:
- Large = 60 60-T5-16
- Small = 18 18-T5-16F for similar final drive ratio.
Could use 25mm wide pulleys to allow for machining.
Motor Bearing - Both Ends: GMN 6201 - data http://www.gmnbt.com/deep-groove-bearings-selection-guide.htm
Planetary support bearing x2 (on drive end of motor shaft) GMN 607
Large output shaft bearing 61808
3 x Gearbox planet carrier shafts ~ 8mm
