Author Topic: Got my eye on a motor.  (Read 4939 times)
12vboywilson
« on: 30, April, 2008 - 09:36:15 »
http://www.everything-ev.com/24v-750w-dc-motor-p-242.html
I'm thinking of putting that on the C5 I get.
Should mean it wont struggle up hills so much, But with it being 3300rpm, It shouldnt exceed the 15mph either =P
Only 40amps max and 24v needed, A decent Li-Ion battery should suffice, Say a 60ah.
What do you think?
blabblub
Re: Got my eye on a motor.
« Reply #1 on: 30, April, 2008 - 09:38:53 »
Not exactly cheap !!
Blabblubububububbubububub
blabblub
« Reply #2 on: 30, April, 2008 - 17:13:53 »
How does that fit into the C5 , is there much modification to be done
Blabblububububub
ogb
« Reply #3 on: 30, April, 2008 - 17:37:41 »
or http://tncscooters.com/product.php?sku=106160
or even more power and as a cheap solution 1000w 36v
or http://tncscooters.com/product.php?sku=106115
for an 350W GEARED Motor - 24 Volts
garywrench
« Reply #4 on: 02, September, 2008 - 21:40:16 »
what gearing sprockets would i need to fit on the motor and on the axle to get this motor to provide 32mph then? I'm time served engineer so fairly capable, just like to make sure that i buy the right parts first time. Do i also need a speed controller (if so which one is best?) and wire as the 24v kit? I'm not fussed about being road legal.
Gary
« Last Edit: 20, October, 2011 - 10:36:47 by BooBoo »
