Author Topic: Pod problem?  (Read 3605 times)
Pod problem?
« on: 24, November, 2011 - 16:43:27 »
I've only noticed this for the first time today when I first put the motor on (battery level on yellow indicator) - the motor load indicator goes into first red light briefly and at the same time the green light on the battery meter came on with it. Here's a quick video to show what I'm going on about (skip to around 12secs.)
Re: Pod problem?
« Reply #1 on: 24, November, 2011 - 18:09:05 »
Hi Kamilb,
Is the battery fully charged? If so then it looks like a loose connection either at the POD or control box, I have the same issue with one of mine and I have to give the connector at the back of the POD a push and it sorts it for a period of time.
Re: Pod problem?
« Reply #2 on: 25, November, 2011 - 20:20:57 »
As Lance says, that red connector wire between the pod and control box can be a real pain and is usually responsible for a multitude of indicated faults.
Try removing the connector from behind the pod and making sure there is no green corrosion on the pins.
Failing that send it to Radiomarty for a bench test  ;)
Re: Pod problem?
« Reply #3 on: 26, November, 2011 - 12:01:34 »
I'll have a look and repot back later today. Corrosion is a possibility as my C5 has only recently come out of a barn after 23 years.
Re: Pod problem?
« Reply #4 on: 01, December, 2011 - 10:37:30 »
Thanks both, I disconnected the red wire going to the back of the pod and there was loads of corrosion on the pins. I cleaned this off, reconnected the wire and the problem has gone.
Re: Pod problem?
« Reply #5 on: 02, December, 2011 - 08:19:32 »
That's excellent news  8)
Re: Pod problem?
« Reply #6 on: 03, December, 2011 - 09:59:13 »
Great stuff, nice and simple repair.  :)
Re: Pod problem?
« Reply #7 on: 04, December, 2011 - 21:40:59 »
Nice one, good to see it is the common issue like normal.
